Front wheels warm ... this normal ??
Old May 19, 2005 | 09:18 AM
Porch40's Avatar
Porch40
Default Front wheels warm ... this normal ??
A couple years ago (150miles) I greased the front wheel bearings using one of those tools shaped like a cone that has an attachement for a grease gun. I cranked enough grease through there to totally remove the old grease and then some .... On close inspection from every angle the bearings looked fully packed. I went through the tightening procedures as described in the manual. Both wheels turned easily so I didn't give it much thought. After taking it for a 2 mile spin the other day I just happened to kneel down and touch one of the wheels. It was warm. Not HOT just warm. Both were. I had done this check right after repacking them and taking a 30mile trip. They were warm then too. Is this normal ? I've done bearings before by hand and never checked the wheel temperature. Only reason I checked this time was to make sure the grease tool hit every corner. Now I don't know what normal is.
Thanks for your thoughts,
Scott
Old May 19, 2005 | 09:23 AM
Graemeinvette's Avatar
Graemeinvette
Normal, depending on the outside temperature. The heat from the disk brakes dissapates through the hub into the wheel.
Old May 19, 2005 | 09:28 AM
Matt Gruber's Avatar
Matt Gruber
that's how i verify all brakes are working
Old May 19, 2005 | 11:33 AM
Pauld's Avatar
Pauld
And if there are aluminium you will notice it more due to aluminium conducting heat so well.
To Front wheels warm ... this normal ??
