headlight vacum help
Old May 21, 2005 | 08:57 AM
vette70's Avatar
vette70
Default headlight vacum help
I'm having a vacuum problem with headlights in up position can't get them down. Can headlights be manually put down and up without vacuum.
Is there a manual release. The valves under dash at steering
don't seem to work.
Pulling what little hair I have left dealing with vacuum.
Old May 21, 2005 | 09:08 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
don't seem to work.
The system is designed so that vacuum holds them down, so if the diaphragm on the actuator is shot, it holds them open.
You need a handheld vacuum pump and this troubleshooting guide:
http://www.corvette-101.com/
Unfortunately since you're having trouble getting them to go down it's probably the diaphragm in the actuator and that means $100 down the drain for a new actuator. But go through the steps. You'll learn alot.
Old May 21, 2005 | 09:20 AM
vette70's Avatar
vette70
Default working with guage and text learning system
Thanks for the note, but still wondering if system can be move manually
when vacuum fails.
Is there someway to get lights down while I try and solve vacuum problem.
Old May 21, 2005 | 09:28 AM
PRNDL's Avatar
PRNDL
when vacuum fails.
If the engine is off and the headlights are still in the up position, they can be fairly easily lowered manually. You have to reach up under the headlight - there is a spot that is like a "locked knee"... you just push on the backside and it bends like your leg would at the knee. But they may just pop up again as soon as you start your engine.
Old May 21, 2005 | 01:34 PM
Wife'sVette's Avatar
Wife'sVette
If they do, just follow the troubleshooting guide and find the vacuum hose leaving the engine ..... disconnect and plug engine side
and if that doesn't work and you don't like the headlights up look ....
There is always Duct Tape
Old May 21, 2005 | 03:37 PM
MKearney's Avatar
MKearney
Default Need headlamps to go down
The actuator has two inlets, one to make it go out with pressure and the other to make it go in. Pull the hoses off and blow into one at a time, if the actuator is working the headlamps will go down when you chose the right hose.
Old May 22, 2005 | 01:46 AM
A78Corvette's Avatar
A78Corvette
Not trying to steel this thred, does my 79 have a vacuum reserve tank? If so where is it?
To headlight vacum help
