+ batt cable
Old May 21, 2005 | 11:04 AM
panchop's Avatar
panchop
Default + batt cable
having trouble seeing where it disapears to. it runs forward under the tunnel. where does it comeout on the firewall?
Old May 21, 2005 | 11:15 AM
Jclgodale3's Avatar
Jclgodale3
it runs inside the tranny tunnel parallel with the transmission via wire clips. Comes out on passenger side of tranny tunnel right at the starter...
Old May 21, 2005 | 11:29 AM
panchop's Avatar
panchop
cool, thats what it looks like. so if i disconect it from the starter it has no other points it is attached to the fame?
Old May 21, 2005 | 11:39 AM
Red 69's Avatar
Red 69
The positive cable attaches to the starter as described. The only other battery cable is the neg and it attaches to the frame in front of the battery compartment behind the driver. Disconnect from the battery also to avoid potential problems if raising the body. Don't forget the radio antenna cable and ground strap.
Old May 21, 2005 | 11:44 AM
panchop's Avatar
panchop
cool. i have that nolan adams checklist. might be a little more to it then i thought. as i have not even gotton half way down the first page and allready have had to resort to drills, impact wrenches and kroil oil along with the usual assortment of tools.
Old May 21, 2005 | 12:56 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Checklist?
Old May 23, 2005 | 06:18 PM
68/70Vette's Avatar
68/70Vette
On my 1968, the B+ battery wire is routed along the right (passenger) side of the transmission tunnel. It's hard to see since it's between the tunnel insulator and the fiberglass transmission tunnel. The firewall insulation blanket extends into the transmission tunnel, and the cable then runs under the insulation blanket until it reaches a point near the starter. At this point the blanket has a hole in it and the battery cable protrudes through to attach to the starter.
From the point the cable runs under the insulator, the cable is hidden from view until it exits at its opening the the insulation blanket.
My tunnel insulator and insulation blanket are new. The insulator might be NOS. The blanket is a repro.
To + batt cable
