Never assume.............
Old May 21, 2005 | 02:07 PM
fl_rider's Avatar
fl_rider
Default Never assume.............
Just a friendly warning so others won't make the same mistake I did.
I recently installed a MidAmerica 9 leaf 2-1/2" spring in my 78.
With stock length bolts the rear of my car had the proverbial Redneck Rake.
I looked on MidAmerica's site and found Part No: 602-850 "Extended Kit, rubber bushings"
This is where I made the assumption that these bolts were the much desired 8" bolts that work so well for everyone else.
WRONG!!
These bolts are a full 5/8" longer than the stock 6-3/8" bolts.
If I am not mistaken this adds up to 7 inches which is a little shy of the desired 8 inches.
Luckily I live in Wisconsin and the local International Harvester shop will have some bolts for me on Tuesday.
Old May 21, 2005 | 09:24 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I think we've all been guilty of this.
Old May 22, 2005 | 04:51 PM
corvettecris's Avatar
corvettecris
I'm just going to ride over to the hardware store and get some 8'' grade 8's, and drill them for the cotter pin. This should work ok, right? I just need to drop 3/4'' or so.
Old May 22, 2005 | 08:06 PM
fl_rider's Avatar
fl_rider
Default Proper size is...
9/16" x 8" Grade 8 and it's your call on fine thread or coarse.
Nyloc's work fine and dont neet to be pinned. there are no rotational forces on those bolts.
Old May 22, 2005 | 08:50 PM
corvettecris
Thanks!
To Never assume.............
