is it possible to accidentally put the left front and right front calipers on the wrong side?.... i was looking at them and seen that the bleeders are at the bottom of the calipers....... i figure that might be my problem..... it would make sense if the bleeder was at the top to let the air out.......
ahh..... that would answer my problems...... i knew it looked weird for a minute.....isht...maybe my back ones are backwards also......... go figure.....
b
How would the mounting plates bolt on wrong?? They are not easy to put on the wrong side. I thought about doing it that way but would have had to modify the brackets.
I don't thing they can be installed backwards
Forget it you are just turning the calipers upside down. I was mounting them on the back of the wheel instead of the front.
i'll have to really see what i screwed up on to make that happen.... i prolly put the lines on backwards too...... not the first time i did something wrong...... live and learn and learn and screw up and get pissed and throw something and then break something else and have to spend another 100 bucks on something u really didn't need
