Using an acetylene torch.
May 21, 2005 | 11:22 PM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Do I need to use goggles if I'm only using the acetylene gas and not the Oxygen?
May 21, 2005 | 11:36 PM
Wow if you use just the acetylene gas you are going to have alot of smoke especially if you are in a building while using it. I never use my acetylene torch without oxygen. What are you using it for anyway? Is it just to heat something up to get something loosened? Goggles are a good idea although I must admit I have used mine to just heat something without using them but I always use a set when welding or brasing. It more dangerous and bad for your eyes using a mig welder with out goggles or a welders helmet.
Fred
May 21, 2005 | 11:42 PM
No oxygen = No heat
I have used "Acetylene only" to soot up an aluminum or copper part prior to annealing with a carburizing flame. Burn the soot off and you have it hot enough to anneal, "soften", the part.
Carburizing flame - Excess of fuel gas - Long feathery tail
May 22, 2005 | 12:01 AM
St. Jude Donor '09
Yeah, I just want to heat some old rusty bolts.
May 22, 2005 | 12:04 AM
Quote:
I kinda figured that is what you were going to do. Use a little oxygen with it and you will heat them up faster and it will burn cleaner.
Fred
May 22, 2005 | 12:22 AM
St. Jude Donor '09
May 22, 2005 | 05:39 AM
I hope the bolts arn't the ones holding the gas tank.?
May 22, 2005 | 08:01 AM
St. Jude Donor '09
Quote:
No, those came out ok. Some bolts on my other cars.
May 22, 2005 | 08:04 AM
Googles or some type of eye protection is never a bad idea.
May 22, 2005 | 08:05 AM
And put some goggles on Len, it's not worth the potential long term damage. My eyes are deteriorating enough without me encouraging them!
Steve
May 22, 2005 | 08:24 AM
St. Jude Donor '09
gotcha guys. I have a hood for the mig welder and goggles for the torch.
The torch goggles are not as dark though.
