Brake light troubles 1968
Old May 23, 2005 | 01:14 AM
TonyLe's Avatar
TonyLe
Default Brake light troubles 1968
My brake lights went out. Checked fuses, bulbs and jumped the switch. Blinkers and tail lights work fine. Any ideas? Its a 1968
Tony
Old May 23, 2005 | 01:28 AM
ffas23's Avatar
ffas23
Tony
Possibly a bad ground. Check your plug ins in your harness. Do you have power going to the switch to begin with? Did you use a test light?
Old May 23, 2005 | 01:49 AM
TonyLe's Avatar
TonyLe
I dont have a test light. just crossed the wires. They worked fine all day then just quit.
Old May 23, 2005 | 02:12 AM
ffas23's Avatar
ffas23
Go an get a test light they are cheap. Get the type with a alligator clip on one end of the wire to go to ground. With the probe part you will test for voltage. It will light up if you have juice. Could be done in the reverse also with these test lights. If you crossed the wires you would be riding around with your brake lights on all day. Is this what you really did? Did you have power before you jumped the switch or did you bring power up from another source to the switch? To tell you the truth I am not sure if there is power going to the brake light switch or if the switch just completes the circuit when it is depressed. That is one reason why you need a test light. Maybe someone else could weigh in on this who knows for sure.
Old May 23, 2005 | 08:22 AM
67tripwr's Avatar
67tripwr
my vote: bad switch
Old May 23, 2005 | 12:22 PM
LemansBlue68's Avatar
LemansBlue68
Originally Posted by 67tripwr
my vote: bad switch
That's a one year only switch but I still see new ones around on ebay and some Corvette vendors.
Old May 23, 2005 | 12:39 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Yes I had a bad switch I needed to replace in the 68 I had last fall. You'll need to be patient in order to bolt in back in way up behind the dash.
Try Mike at Americas Finest Corvettes at 760-789-8423. He has a ton of used parts.
Greg
Old May 23, 2005 | 01:02 PM
theandies's Avatar
theandies
Why go get a used switch. Autozone has what you need and it's less that $10.
Old May 23, 2005 | 01:14 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The correct one for 67-68 Vettes or a generic replacement?
Old May 23, 2005 | 01:16 PM
PRNDL's Avatar
PRNDL
The 68 uses a unique different 1yr only switch. Just about every other year uses a standard plunger type switch. I pretty easily adapted the plunger style switch to work in my 68. (Somebody on the forum explained how to do this). So, you can go either way. I have a replacement correct 68-style switch that I will some day install. But if it's not your switch you will be wasting your time and money.
(The correct one for 68 is 68-only, not 67-68)
Additional info: What I find amazing is that even tho this part was only made 1 year and only for corvettes (as far as I know), it is still available today! AC Delco part # D886
Old May 23, 2005 | 01:59 PM
TonyLe's Avatar
TonyLe
The brake lights did not come on when i jumped the wires to the switch. Thanks for all the replies.
Old May 23, 2005 | 04:21 PM
72GACRZR's Avatar
72GACRZR
The tail lights use the same ground in the back, so I would put power to the wire at the switch end(jumped?) and see if you can see it at the socket end(you could run a long power jump to the rear and hook it to the first connector.
Check the wires to the rear and see if one got grounded to the frame somewhere.
PS
When you get a test light, have someone apply the breaks and test the out side of the switch, if you have power, it's in the wiring to the rear.
Old May 23, 2005 | 09:33 PM
Surfer Dan's Avatar
Surfer Dan
If both rear turn signals work, and courtesy lights work, test with test light the white wire at stop light switch with pedal depressed. If light glows the switch is working, light goes out with pedal released. (Always check test light ground, the best ground is at Bat -, if wire is to short clip it to the courtesy light switch (nut) making sure it isn't covered with 37 years of paint, check fuse box for power.) Ok the test light works, always test it. So you have Bat + volts at white wire with pedal depressed go up to turn signal switch gang connector (arched plug on steering column with 8 to 10 wires on one side of connector and 8 wires on the other side) Ok now test the white wire on the end of connector with pedal depressed test light should glow. Ok test the mating wire (the continuing wire, it is black with a white stripe) Power with pedal depressed? Ok, the two wires next to the Black with white are dark green and black with yellow stripe (confused yet?) With pedal depressed both the dark green and the black with yellow will glow the test light IF the turn signal switch is NOT faulty. Any questions?
Old May 24, 2005 | 04:32 PM
TonyLe's Avatar
TonyLe
I started testing all these wires and musta jarred something, cuz they started working again, thanks for all the help.
Tony
Old May 24, 2005 | 10:11 PM
Surfer Dan's Avatar
Surfer Dan
You're vetty velcome
To Brake light troubles 1968
