How Much HP?
How much Horsepower can I get this 350 up too with out getting to much? is 375-425HP about right? Can I use the stock heads(of course rebuild them) or should I go aluminum?
Anyways you need to change the heads, that's the key to power. Seems like you have everything else in place. Lower gears is a wise choice. You don't say how many miles are on your short block. If you've lived a good life your bottom end should take 400 HP range and that's about all you can get a N/A 350 to and stay streetable anyways (without high tech options added).
Check out my signature: my 383 in Olivier's car was 1.5 seconds faster for the reasons I stated above.
Hopefully your headers are going to a true dual exhaust, at least 2" diameter pipes with new or no cats & decent flowing mufflers...
Set your distributor up like this: How to set your timing for peak performance by Lars
Unless its been done already there is a good chance you could find some power by tuning your carb, probably richer.
Switching to an electric fan instead of the belt driven clutch fan will free up a few horses.
Fuzzy dice from the rear view mirror are good for about 10 horses.
Otherwise here is a quote from an old race engine builder I know...
"Speed costs money, how fast do you want to go?"
That will make a huge difference... assuming brake HP.
That would be about 330-340 rwhp. And that will still require HEAVY mods.
A 300 brake HP car should make about 250-260 rwhp
***depending on tranny and gearing...
which would be a low 14 to a mid to low 13 second car with a good setup.
YOU WILL NEED HEADS and good intake... can be iron (HEADS) but something with a small chamber 58cc-64cc 2.02 valves (maybe 1.94) //vortec heads a good and cheap?//
Head flow numbers depends on cam selection which depends on gear and tranny and exhaust....
QUICK! SOMEBODY GET OUT THE DEAD HORSE!!!**KEY**
Gotta have a budget and a goal... and decide who is doing the work.
I am shooting for mid 12's in my 77 vette... I am almost 6k in it. Not including the car...
JUST parts and labor and things that POP up.
good luck
I of course will see what the 3:70 rear does, and then make a plan for the motor for this winter.
sounds like i will probably pull motor and go through with new heads, possibly alumium for good flow and shoot for @400hp.
Longtube headers and at least 2.5 in pipes. Should be close to 400hp.
