proper way to jack a C-3
I have been told many different versions but whats the correct way to put your car on jack stands without tweaking the body?
1 Post
Originally Posted by panchop
i HOPE this is it.
........ well, if the owner isn't around, I guess you just smash the window, open the door, and hotwire the sucker. If the owner is nearby, hit him over the head first, and proceed as above.... but I wouldn't recommend it!
1 Post
Originally Posted by LIQUIDDRAGON
i would have to say that it would not be a good idea to put to much weight on the front end of the car with the front stands where they are. the front stands are suppose to be on the frame rails in front of the front cross member.
Location: San Diego - Deep Within The State of CONFUSION!
Originally Posted by SpcCox
I put mine in the places described and i open the doors and open the hood regardless of what im doing to relieve stress.
Who the heck knows, any more!
Senior Member since 1492
i HOPE this is it.
I move the front two stands and place them under the sway bar mounts.
Originally Posted by SanDiegoPaul
Wow jury's still out on that too I see. I was always taught at Chevy Dealer to put tee tops on, and NOT open any doors as long as car was on the rack.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by c3andc5
You are correct. NEVER open the doors on a C3 when it's on a lift supported by the frame. Bad juju! OK on a drive-up lift.
Originally Posted by lostpatrolman
I fail to believe this makes any difference on a car with a halfway decent frame. Our cars are 23-37 years old, have been abused and lifted by several different methods, by several different bubbas all while opening doors, removing ttops, etc. and most of these cars show no signs of this.
Many times,I had previously jacked this Vette up on one side,doors closed,with no problem,and I'm talking 18" from the garage floor.
