spring projects
Old May 31, 2005 | 04:14 PM
Carrot's Avatar
Carrot
3rd Gear
Default spring projects
Completed all my spring projects:new mounted seat covers, u-joints replaced,trans leak sealed, even replaced the clock. Time to remove the t tops and enjoy the the 80 corvette and a corvette summer. How are the rest of you doin?
Old May 31, 2005 | 04:53 PM
baja216's Avatar
baja216
I just completed my new rear spring install a few weeks ago, as well as new shocks front and rear.
This past weekend I installed a high torque starter to eliminate the heat soak. While I was at it I changed the oil and replaced the bushings on the front sway bar link.
Old May 31, 2005 | 05:45 PM
jcbass7's Avatar
jcbass7
im still trying to buy mine.. but once i do ill have a corvette summer as well.. but im guessing mine will be mostly underneath it or under the hood getting it ready for the road
Old May 31, 2005 | 09:00 PM
kdf1986's Avatar
kdf1986
Just installed the new carpet, brake console, door pads and cleaned all the interior trim. Took out the back window and put it in the holder, T-Tops off....and went for a Memorial Day Cruise.
kdf
Next is to install the new seat foam and seat covers.
Old May 31, 2005 | 09:25 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Mine was pretty lengthy... heads, cam, intake, carb, suspension kit, valve covers, air cleaner, powder coating..all before CI. I just resealed my rear window and am waiting for the mail man to deliver the new rear trim ring for it! Tomorrow the car goes in for an alignment check. Later this month, I am changing half shaft ujoints.....
Old Jun 1, 2005 | 01:23 PM
71redskin's Avatar
71redskin
i'm waiting for my rag joint to come in along with a new oil pressure gauge... just finished with dist. rebuild and carb tuning.... getting to be fun to drive now... but i think i'll trailer it to carlisle...
To spring projects
