Drive shaft u-joints
Old May 31, 2005 | 05:03 PM
steves_77vette's Avatar
steves_77vette
Default Drive shaft u-joints
I had pressed out the u-joints on my drive shaft and was preparing to put in the new grease-less u-joints and noticed immediately that the new ones are about 1/4 shorter than the original u-joints. The originals were grease-able u-joints, clearly with the grease zerk. I didn't think there was a length difference between the two types are there? Or did I get the wrong joints from Corvette Central? The box says they are greaseless drive shaft joints of the right model year vintage.
Ideas? This is for my '77 Vett
Old May 31, 2005 | 06:49 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I spent some time looking at these this weekend.
I'll say up front that I'm no expert, but what you're describing doesnt sound right. With or without zerk shouldn't matter. The joints are held in place by expansion clips so they have to be the same distance from cap to cap. Otherwise they'll move back and forth.
1/4 inch sounds like an awfully big difference to me.
Old May 31, 2005 | 06:57 PM
rosslato's Avatar
rosslato
i've used both and there was no difference in size, exactly the same
Old May 31, 2005 | 07:02 PM
Sharky Guam's Avatar
Sharky Guam
I too have used both kinds with no issues. Somehow, you have an incorrect U Joint.....
Old May 31, 2005 | 07:21 PM
dennis's Avatar
dennis
there is a smaller joint for pre 71 4speed. I found out when I changed the trans. Had a 71 driveshaft. Used the larger joint.
I actually had to use a 2 way to fit the wrong driveshaft,(wide joint), to the correct 70 4speed output shaft,(small joint).
There all large joint after 70. Auto or 4 speed.
Old Jun 1, 2005 | 12:42 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I think you got the wrong ones. Your u-joint should be a 790 also called a 1330 u-joint. I think they gave you 785's which are also called 1310 u-joints. Either way they are wrong.
Old Jun 1, 2005 | 06:58 PM
steves_77vette
To finish the story I went by Napa today and picked up a pair of u-joints, greaseless and these match the originals. So, Corvette Central has the wrong u-joints for future reference. Either that or the wrong joints in the right box.
To Drive shaft u-joints
