I need fuel gauge help!!!
Old May 31, 2005 | 08:17 PM
chadman's Avatar
chadman
Default I need fuel gauge help!!!
I installed a new fuel gauge while my car was down. After getting it running the gauge would only go to 1/4 when full. I grounded the wire at the sender and it went full. I thought that my sender had to be bad, well today I installed a new sender with the same result. Shows 1/4 when full, and still goes full with the wire grounded at the sender. How can I tell what is wrong? Anyone have any tips? I can't believe that new one is bad with the exact same symtom. Could I have hooked something up wrong at the gauge??
Old May 31, 2005 | 10:27 PM
RRROBB's Avatar
RRROBB
I've got the EXACT same problem!!!
I figured it is the ground for the instrument circuit board especialy since the only other instrument that works is the clock.
Old May 31, 2005 | 10:30 PM
SkunkApe's Avatar
SkunkApe
Sounds like a grounding issue or a resistance short. Check all grounds.
Can you get to the back of the fuel guage? Run your own wire and test again.
To I need fuel gauge help!!!
