VIN Engine ID Numbers
Old Jun 3, 2005 | 11:39 AM
tonyd21266's Avatar
tonyd21266
Default VIN Engine ID Numbers
194378S419741
researching this vin
what denotes the engine
i always thought it was the 5th but isnt that part of the convert / coupe
is there a guide on this sit or doese anyone know of a good one
Old Jun 3, 2005 | 12:26 PM
mstanton's Avatar
mstanton
4th digit tells coupe or vert. 3=coupe 6=vert. Starting in 72 5th digit gave engine. Before 72 no engine code in vin. Corvette Black Book or Corvette by the Numbers are both good references.
Old Jun 3, 2005 | 01:01 PM
tonyd21266's Avatar
tonyd21266
ok how do I know the original engine short of the tank sticker
Old Jun 3, 2005 | 01:41 PM
sb69coupe's Avatar
sb69coupe
You don't know for sure without the tank sticker or other documentation. There are clues though. For your car (a '68, right?) tell us the following things:
width of radiator core, and whether it has an external supply tank or if it has a fill cap on the side tank of the radiator itself
redline on tachometer
metal fuel lines from the tank to the engine compartment, one or two?
rear sway bar?
how are the u-joints fastened to the rear differential? are there u-bolts or are their caps with bolts holding the u-joints to the side yokes in the differential?
big block hood or smallblock?
auto or manual transmission?
To VIN Engine ID Numbers
