trailering
Old Jun 9, 2005 | 02:40 PM
7DStingray's Avatar
7DStingray
Default trailering
Just wondering where the best spot to hook your tie down straps for trailering
Old Jun 9, 2005 | 04:46 PM
jdwhealton's Avatar
jdwhealton
Whatever you can get at! I also strap to each wheel and the traier sides/corners. I pulled this one back from mid-Florida to eastern NC running 70-85 mph with no troubles.
Old Jun 9, 2005 | 06:46 PM
70Donnybrooke's Avatar
70Donnybrooke
I go off the A arms in the front using axel straps. You have to use the ones with the heavy duty cover on them or they will fray. In the back I have seen two ways. I go around the half shafts all the way nearest to the universal. Some people say that is a bad spot. I have been doing it this way since 99 and never had a problem. I had asked a towing company what they would do and they said they would go around the half shafts. I also have seen people go of the rear spring, but I think that is looking for trouble. To me it don't seem right.
Old Jun 9, 2005 | 06:52 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
I think the webs that go around the tires are the best way.
Old Jun 10, 2005 | 06:04 AM
guppie's Avatar
guppie
St. Jude Donor '08
Caution: For those that have front spoilers like my 78 be careful on the front. I hooked mine where the spoiler was in jeopardy when the suspension flexes up and down with travel and the tiedown can hit the spoiler and crack or split it.
Old Jun 10, 2005 | 10:35 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Front: lower a-arms (use a regular hook)
Rear: there's a slot in the frame on both sides right behind where the fuel tank crossmember attaches. I hook the rear hooks right into that slot.
Trailered the '68 like that for a total of over 3000 miles even through the Tennessee mountains with no problems..
Old Jun 10, 2005 | 12:46 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Oliver, Not picturing this? How does the strap...hook to the frame up buy the gas tank and clear the lower fenders when strapped to the trailer? Did you install some mounts to the floor rather than the outer trailer frame?
I guess I must be nieve. I just run the strap around the strut rods close to the trailing arm. If it can handle the torque and hp those BB engines deal out when launching, why can't it hold the car on the trailer?
Bullshark
Old Jun 10, 2005 | 12:51 PM
70Donnybrooke
Bullshark
When I bought my car one of those strut rods was bent from someone using it to jack up the rear wheel.
Old Jun 10, 2005 | 12:59 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Larry, Are you sure that was the reason it was bent? Bending those strut rods was a common "lazy mans practice" for adjusting them when the bushings wore to the point that the adjustment bolt was out of range. It took a pretty big sledge hamer to apply bubba adjustment
Bullshark
Old Jun 10, 2005 | 01:06 PM
70Donnybrooke
Bullshark
That is always a possibility. I was told that sometimes it occurs that way. I replaced everything suspension wise when I got the car. The bushings were bad and it was bubba'd up. When the bushings at the spring ends went they used washers. To go through all the problem to put them in there, when all you had to do was buy a 20 dollar kit. After I seen how bent it was I was afraid to strap it there. I do know it was not for the alignment, because the wheel was really pointed out at the top.
Old Jun 10, 2005 | 02:11 PM
GrandSportC3
Gonna provide pics of how the car is tied down on the trailer tonight when I get home from work..
Old Jun 10, 2005 | 06:27 PM
GrandSportC3
Here's how my Vette is tied down in the rear.
To trailering
