serious front suspension squeakage
Old Jun 10, 2005 | 09:05 PM
Sacredgrooves's Avatar
Sacredgrooves
Default serious front suspension squeakage
69 350 4 spd
front passengers side has developed a wicked squeak. I cannot quite pinpoint where though I believe it is in the upper control arm area. I push down and with the hood up it seems to be there when the control arm "rotates" the car has poly bushings but they have been on 5 years(4,000 miles) and this just started about a week ago. suspension feels tight and I cannot see anything that is loose or broken. what do you think?
Old Jun 10, 2005 | 10:34 PM
rihwoods's Avatar
rihwoods
Hit those poly's with WD-40 or silicone and see if it goes away..
Old Jun 10, 2005 | 11:14 PM
Sacredgrooves
my lower ball joint on the passenger side(where I hear the squeaking) has a torn boot with grease all over the joint. is it safe to assume the ball joint is bad and making the racket? if so, is their a better than stock replacement I should install? (the entire suspension was redone during resto 4,000 miles ago-should I change both lower ball joints?)
thanks, Dave
Old Jun 10, 2005 | 11:43 PM
rihwoods's Avatar
rihwoods
Do both sides.
Maybe others can advise on aftermarket ball joints...
Rich
To serious front suspension squeakage
