What throttle cable bracket you running?
Old Jun 13, 2005 | 06:50 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default What throttle cable bracket you running?
Well I'm getting ready to finish up my re-install, but now I see that my old throttle bracket I used with the Victor Jr intake isn't going to work on the RPM Air Gap. I have a new Lokar Hi-tech throttle cable that I'm going to use with the Mighty Demon carb.
Show me what your using, what works, and what the part numbers are.
Thanks. With any luck, I'll be firing it up this weekend
Old Jun 13, 2005 | 07:21 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Stock bracket for a 4sp & Holley carb. Gonna switch to a Lokar one day.
Old Jun 13, 2005 | 09:29 AM
SmokedTires
St. Jude Donor '05
Thanks Len, that's what I was using, but I added a bracket to it because I didn't like having to clamp down hard with the carb nut to keep the thing from rotating. The bracket I added, also bolted to the intake securing it in place. Since the new intake is different, I'm looking to see if I can find something that is both secure and looks good
Old Jun 13, 2005 | 09:54 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Yeah, my original has a small tab which bends down to sit in the groove at the base of the Holley carb. Not all Holley carbs have that little groove in the base though.
The little tab helps keep the bracket from rotating.
Old Jun 13, 2005 | 10:24 AM
rosslato's Avatar
rosslato
this is the strongest sturdiest brkt i've ever seen, it mounts to 2 bolts on the intake manifold, it comes w/2 adjustable bkts. don't know who makes it and haven't seen another one. problem is i can't use it anymore w/new bowtie 200r4 tranny.
grayhook's Avatar
grayhook
this is holley's throttle bracket....
Old Jun 13, 2005 | 10:32 AM
rosslato's Avatar
rosslato
OOOH, thats awesome
Old Jun 13, 2005 | 10:40 AM
grayhook's Avatar
grayhook
OOOH, thats awesome
thank's! it was built by brettmc! run's as good as it looks too!
Old Jun 13, 2005 | 10:55 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I found both a Lokar cable and bracket on good 'ol ebay, might take a look
Old Jun 13, 2005 | 10:57 AM
SmokedTires
St. Jude Donor '05
Grayhook, that does look nice . Maybe that'll be the one on order later today
Old Jun 13, 2005 | 10:59 AM
SmokedTires
St. Jude Donor '05
Yellow, the Lokar looks like a nice piece also. Does it seem pretty secure from being able to rotate after being installed?
Old Jun 13, 2005 | 11:45 AM
Buzzardz_vette's Avatar
Buzzardz_vette
Where did you get the Corvette wiper cover? I like it.
Old Jun 13, 2005 | 11:46 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Sure does, it even has an adjustable stop to align the bracket with the carb/cable
Old Jun 13, 2005 | 11:47 AM
grayhook's Avatar
grayhook
rosslato you got it look'n good under there!
Old Jun 13, 2005 | 11:56 AM
rosslato's Avatar
rosslato
got it from ecklers, it comes plain jane, put my own design on it. really cleans up that ugly wiper area, big difference
Old Jun 13, 2005 | 11:57 AM
rosslato's Avatar
rosslato
thanx greyhook, rite back at ya
Old Jun 13, 2005 | 02:29 PM
LFZ's Avatar
LFZ
Lokar $19.99 bracket..works great, and clears any air cleaner base i throw at it.
To What throttle cable bracket you running?
Old Jun 13, 2005 | 03:23 PM
Buzzardz_vette
It looks like raised lettering in the pic. How did you do it and where can I get the supplied to do it to mine?
I use a bracket I bought at Pep Boys. Works great for me. Has the bracket for the throttle cable and the auto trans kickdown cable. I had a question on the throttle connector in another thread if anyone here can answer it.
http://forums.corvetteforum.com/show...6&forum_id=119
Thanks.
Old Jun 13, 2005 | 03:26 PM
SmokedTires
St. Jude Donor '05
Thanks everyone, looks like I'm going to go with the Lokar
Old Jun 13, 2005 | 04:17 PM
rosslato's Avatar
rosslato
Thanks.
buzzards vette,
it is raised lettering. i also found it in ecklers catalogue. it's i think a stock part on one of the c5 vettes that they use on their valve covers. didn't know when i bought them that they were raised but it turned out better. they come w/adhesive and they're very fragile. u apply them 1 letter at a time however u want them. good luck
