brake rotor rivets needed?
Old Jun 13, 2005 | 05:38 PM
vette fiddler's Avatar
vette fiddler
Default brake rotor rivets needed?
Do the brake rotor rivets really need to be replaced? The lug nuts hold the rotor tightly in place anyway. Is it overkill? is it unsafe not to have the rivets or some kind of bolts?
Old Jun 13, 2005 | 05:45 PM
Twin_Turbo's Avatar
Twin_Turbo
No, the rivets are only used by the factory to turn the rotor on the spindle (rear) or hub (front) so that they are absolutely true.
Old Jun 13, 2005 | 05:50 PM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
Originally Posted by Twin_Turbo
No, the rivets are onlu used by the factory to turn the rotor on the spindle (rear) or hub (front) so that theya re absolutely true.
Old Jun 13, 2005 | 06:08 PM
rcread's Avatar
rcread
GM placed the rivets there to make it difficult for me to replace the rotors 34 years later (they succeeded). Go easy on the person who replaces your rotors in 34 years and don't replace the rivets.
Old Jun 13, 2005 | 09:18 PM
72LS1Vette's Avatar
72LS1Vette
Yeah, WELD them on.
Rick B.
Old Jun 14, 2005 | 07:00 PM
vette fiddler
QUESTION: I have ordered some front rotors from Van Steel cause the rotors miked at 1.200, but I was'nt thinking about the 'turn the rotor for absolute true' step. I thought changing the rotor was something I could do. Do I need to take it to a Brake Shop to have this done anyway? :o Since I look this dumb I may as well go all the way......the old pads are still very thick. can they be prepped for continued use with the new rotors?
Old Jun 14, 2005 | 08:31 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
dont remind me
i got kinda pissed when they ate my drill bits
so I pulled out the air hammer
Old Jun 14, 2005 | 09:21 PM
68sbShark's Avatar
68sbShark
I was able to drill mine out in about 10 minutes per rotor when I did the rear shoes (parking brake) last weekend. Really wasn't a big deal at all. I had a good quality bit and kept it oiled while drilling.
~Rich
Old Jun 14, 2005 | 09:36 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Originally Posted by Corz
dont remind me
Jezes man did you have the bit in backwards
Old Jun 14, 2005 | 10:13 PM
1980 454's Avatar
1980 454
Let the bit do the drilling if you press hard enough you wont bite !
Old Jun 14, 2005 | 10:27 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Old Jun 15, 2005 | 09:01 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The rotors don't have to be turned on the hub. When your ready to install the rotor, make sure there are no knurls on the hub where the old rivits were. This can be done by lightly grinding over the rivit holes. Than bolt the rotor on and tighten all 5 lug nuts. Put a dial indicator on the rotor and spin it to see what your run out is. I like them to be 7 thou and under but 10 is acceptable. If your higher than that, rotate the rotor one position and repeat the process until you find the lowest runout. Pads are cheap, I replace them when I put rotors on my cars.
Old Jun 15, 2005 | 01:16 PM
vette fiddler
Thanks Van Steel! You guys are great and always on top of things.
Old Jun 15, 2005 | 01:23 PM
Ironcross's Avatar
Ironcross
The high dollar premium rotors use have the rivets in the box. [ie] Bendix. Imported cheap rotors never did.
Old Jun 15, 2005 | 01:36 PM
Twin_Turbo's Avatar
Twin_Turbo
and how would you go about installing those rivets? it'd be easier to drill & tap for machine screws.
Old Aug 30, 2020 | 08:37 PM
Cobratei's Avatar
Cobratei
~Rich
Really, Replacing parking brake shoes?
Why would you need to replace your parking brake shoes. They don't wear out, of course unless your using them to stop the car. I own a 2002 with over 245000 miles. It still has the original shoes.
Old Aug 30, 2020 | 08:47 PM
MelWff's Avatar
MelWff
First this is a 15 year old thread.
Second this forum is for C3 Corvettes which dont use the same system as a 2002 and the OP has a 33 year old parking brake system.
Old Aug 31, 2020 | 03:38 AM
vettebuyer6369's Avatar
vettebuyer6369
You are responding to a post from 15 years ago.
To brake rotor rivets needed?
