grade 8 bolt....failures...all read
Old Jun 14, 2005 | 01:59 PM
onaqwst's Avatar
onaqwst
Default grade 8 bolt....failures...all read
http://www.hotrodders.com/t64273.html
i seen this on the hotrod site...... it has a listing of bolts that seem to fail.....mostly overseas bolts......
b
Old Jun 14, 2005 | 02:09 PM
iNdigo's Avatar
iNdigo
yup, gotta love the hotrodders forum.
always a source of pertinent and highly useful information. highly knowledgeable forum members, the majority of which either run their own shops, are deeply entrenched in a technical field, or at the very least aren't afraid to lay their hands on a wrench and get a little greasy.
the blonde weasel
Old Jun 14, 2005 | 03:54 PM
mrvette's Avatar
mrvette
I am not aware of any foreign bolts in my car except maybe the ARP put in the engine, rods, caps, heads...back in '97....
other than that, they came out of my olde tyme dusty bin I bin savn' for about 40 years.....thems bolts got 'charactor'....
GENE
Old Jun 14, 2005 | 04:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I thought ARP was in California ?
Old Jun 14, 2005 | 05:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Printed this one off so I can compare to what I see at Lowes and Ace.
Old Jun 14, 2005 | 06:16 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Too bad the scans are so bad!
Old Jun 14, 2005 | 09:16 PM
markdtn's Avatar
markdtn
Good info.
Old Jun 14, 2005 | 09:19 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Too bad I couldn't read any of it
Wish it was in Adobe.
Dep
Old Jun 14, 2005 | 09:33 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
This any better?
Old Jun 14, 2005 | 09:35 PM
1BAD80's Avatar
1BAD80
Beaten to it by Jughead
Old Jun 14, 2005 | 09:54 PM
DJ Dep's Avatar
DJ Dep
Thanks Len!!!!
Dep
Old Jun 14, 2005 | 09:56 PM
DJ Dep's Avatar
DJ Dep
Hmmmmm....anyone see a pattern with the names of those manufacturers??? Guess we need to bring back that saying "cheap Japanese junk".
Dep
Old Jun 14, 2005 | 10:05 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Wait till the Chinese undercut the Japanese. No love lost between those two.
Old Jun 14, 2005 | 11:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Interesting...I would expect Chinese bolts to be crap, but I'm a bit surprised that the Japanese make so many suspect fasteners. They're usually nuts on the quality control.
Old Jun 15, 2005 | 06:39 AM
mrvette's Avatar
mrvette
Japanese on Quality Controll?? where in hell you ever get that idea?? some advertisement???.....in history their steel has allways been reprocessed and therefore something differant about it, I THINK it's higher carbon or other impuritity content on account of the resmelting.....these daze we are in sort of the same boat as the Messabi iron range in Minn, west of Duluth is played out, so I hear....and that is the reason American steel is hurting so badly...no ore....
Manchuria has iron ore and coal in China, that is why the Japanese in WW2 went into those areas....no other....
GENE
Old Jun 15, 2005 | 07:09 AM
GOSFAST's Avatar
GOSFAST
Default Valve Spring Wire
A while back much of the wire used to make valve springs for many of the cam manufacturers came out of Kobe, Japan. We ran into many broken valve springs at that time. We tried to use only the springs that were manufactured with the wire from Rockwell International. This may be all changed now, but this is how it was then.Thanks, Gary in N.Y.
Old Jun 15, 2005 | 07:23 AM
BerniesVette's Avatar
BerniesVette
I buy Caterpillar grade eight bolts and have never had a failure.
Bernie
To grade 8 bolt....failures...all read
Old Jun 15, 2005 | 07:31 AM
mrvette's Avatar
mrvette
Bernie
At one time, the aircraft industry was plagued with bad bolts from foreign sources....thinking of Korea as I recall.....anyway, I would hope that's changed now....they used a method of tracing/sealing/tracking boxes of bolts, and require one in ten be destructive tested...something like that....no sense having airplanes falling outta the sky....
Bet a airframe/engine mechanic knows lots more than I do about this topic, and will chime in soon enough...
GENE
Old Jun 15, 2005 | 07:57 AM
UKPaul's Avatar
UKPaul
Our theory for the last 30 years is that *** steel is obtained from melted down *** ships sunk in WWII..........
*** quality control is good, the problem is that the steel isn't
Old Jun 15, 2005 | 08:28 AM
Chumpzilla's Avatar
Chumpzilla
Just bought some grade 8 yesterday..... they had "JH" on the top... not on the list so I guess I'm in the clear.
Course, they're just going in to hold the steering column in place so I'm not too concerned about them failing....
