Braided Vacuum line
Old Jun 14, 2005 | 03:31 PM
kona's Avatar
kona
Default Braided Vacuum line
Anybody know of a good source for Braided Vacuum line? I just hate all the lines on my 80 and was thinking braided lines would help to dress it up.
Kona
Old Jun 14, 2005 | 03:53 PM
Jlreyna's Avatar
Jlreyna
I think Summit Racing offers braided kits.
Old Jun 14, 2005 | 04:05 PM
CGGorman's Avatar
CGGorman
How much you willing to spend? REAL stainless braided line from Aeroquip will run you several hundred up to a grand...
Old Jun 14, 2005 | 04:10 PM
kona's Avatar
kona
I'll check out Aeroquip I need size -4. Don't want to spend an arm and a leg but I am willing to drop a couple hundred if it means cleaning up that mess of black line.
Thanks for the info.
Kona
Old Jun 14, 2005 | 05:11 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Carefull what you wish for, all those hoses in braided could look like more of a snakepit than it does now....
Old Jun 14, 2005 | 05:18 PM
SteveG75's Avatar
SteveG75
The black lines tend to blend with the firewall and fenders. Also braided lines will get hot, after all they are metal.
There is a fine line between enhancing the engine compartment and rice IMHO.
Sorry, just my $0.02.
Old Jun 14, 2005 | 05:27 PM
zymurgist's Avatar
zymurgist
Personally, I would use fresh black line and route it neatly, using black nylon ties to keep it orderly. Looked good on the old L48. Funny how much of that stuff went away when I installed the 355.
Old Jun 14, 2005 | 05:30 PM
Twin_Turbo's Avatar
Twin_Turbo
how can the metal lines get any hotter than rubber lines? Please explain???
Old Jun 14, 2005 | 05:47 PM
SteveG75's Avatar
SteveG75
Just my opinion. But metal is a better conductor of heat and if any of the lines are connected to the intake manifold. Personally, I think braided lines are good for fluids (brake, fuel, PS, maybe coolant) but too much for vacuum lines. Just my $0.02.
Now, I'll go shut up before Dep accuses me of steeping in poop again.
Old Jun 14, 2005 | 06:05 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I think he's right about the braiding.. the teflon will insulate slightly but it will hold heat more...
Old Jun 14, 2005 | 06:18 PM
rcread's Avatar
rcread
As for the looks, I agree with the others that the black is more subtle and will draw less attention if routed properly. You don't want the vacuum lines to be the thing that pops out when people look at your engine bay.
Old Jun 14, 2005 | 07:25 PM
Twin_Turbo's Avatar
Twin_Turbo
It's the fluid inside that will make the hose hot or not, on braided or normal the rubber is the main insulator, that said the steel braid can never get hotter than the rubber is on the outside wihtout an external source of heat warming up the braod and because the steel braid is a better conductor it will probably run cooler a sthe braid is a better conductor and has a much larger surface area than the rubber on top of that. What feels colder to the touch, a section of braided hose or plain rubber hose?
Old Jun 14, 2005 | 07:35 PM
Z-man's Avatar
Z-man
A rubber line at 200 degrees is *much* cooler than a 200 degree stainless line.
Actually, I like the stainless look. There is nothing "rice" about it - "airplanes have been around longer than ricers." On high pressure hoses, the steel will protect the internals and keep the line from collapsing at bends. If color is a problem, they now have black kevlar wrapped hose in addition to the SS.
Old Jun 14, 2005 | 07:40 PM
Twin_Turbo's Avatar
Twin_Turbo
Oh yeah? a 200 degree rubber line is not cooler than a 200 degree rubber line linered with steel. the only difference is the braid, so if you take off the braid and assume both rubber hoses are the same the rubber surface will be the same temp on the outside for the same fluid temp, then add steel braid to 1 of them, does the braid get hotter than the rubber surface now? If you can make that work you have just had energy jump a medium (rubber) and you should patent the process immediately, it will be a scientific break through.
A 200 degree line is a 200 degree line, (if you want to argue surface temps), 200 degrees is what determines the temperature, not the material, same as a 200 ton pack of feathers is just as heavy as a 200 ton block of steel..
Old Jun 14, 2005 | 09:13 PM
Empatho's Avatar
Empatho
Old Jun 14, 2005 | 11:14 PM
WhichVette?'s Avatar
WhichVette?
As I recall from some field trip to some science museum a LOOOOONG time ago, different materials at the same temperature will feel hotter/cooler due to the transfer of heat between it and your hand.
Personally, I think braided vacuum hose would look a little too
But, opinions are like a$$holes...
Old Jun 14, 2005 | 11:51 PM
Bangkok Dean's Avatar
Bangkok Dean
Just A little question folks but who grabs hold of a item with there bare hands when they know it is 200 degrees rubber or rice on purpose?
To Braided Vacuum line
Old Jun 15, 2005 | 01:29 AM
Z-man's Avatar
Z-man
Easy, easy!!! Note the exaggerated statement followed by the lol emoticon...I was kidding!
I also wanted to follow up with my "a pound of feathers is lighter than a pound of steel" quote, but I thought it would be too obvious and you beat me to it.
Old Jun 15, 2005 | 11:46 AM
vettfixr's Avatar
vettfixr
Well, my engine is anything but subtle but I don't think it's rice either. Maybe old school. All of my hoses came from Summit. They are from Spectra and are not AN hoses but normal SAE sizes with braided covering. The clamps are also from Spectra and are band clamps with covers. The cost for doing the entire engine and all vacuum lines under the hood, including those going to the headlights was probably about $200 if I remember correctly. So far, after being on the car for about 2 years, no problems have occurred and there are no leaks either.
Old Jun 15, 2005 | 12:02 PM
toddalin's Avatar
toddalin
Think this looks too "rice?" These are all Spectre and I've had no problems with them or their clamps for over 10 years.
