While you folks were all watching HBO reruns, I finally found a spot for my MSD ignition box. I removed the vent and put it in the stock CD box location, just above the stock starter solenoid. This location is nice and dry, and I can see the power LED and switches from the engine compartment just below the radiator overflow can. Added bonus, the positive battery lead is about two inches below it.
There's actually quite a bit of room behind the wheel. I might stick the coil back there also....
