carb/intake setup
Old Jun 15, 2005 | 02:04 PM
lg4vette's Avatar
lg4vette
Default carb/intake setup
What carb/intake combo that is emissions-compatible and able to fit under a stock '80 hood would you all suggest? Would the factory dual snorkel airbox also be compatible?
Thanks.
Old Jun 15, 2005 | 03:09 PM
page62's Avatar
page62
Stock QJet with stock intake manifold. Seriously! The carb and distributor just need to be tuned for better performance (and then perhaps detuned for emissions testing as needed).
If you don't believe me, look:
Stock carb & intake...and the car runs like a scalded cat. Secret is the cylinder heads (and L82 cam).
Old Jun 15, 2005 | 04:29 PM
mvftw's Avatar
mvftw
Pull EGR & use Electric choke & plug unused vacuum lines...
Old Jun 15, 2005 | 07:11 PM
lg4vette's Avatar
lg4vette
Sounds like good advice to me based on your picture. If I use a GM 260 HP long block, are the heads and cam a good combination with the stock intake/carb? Or would I be better off using the block I have (non corvette 69-79 350) and put different heads/cam in it with the intake/carb? I'm interested in low-end torque and a smooth, quiet idle for cruising as opposed to high hp.
Great looking engine compartment, by the way.
Old Jun 15, 2005 | 07:15 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
go for sleeper! leave it stock APPEARING outside and under the valve covers, all bets are off!
Old Jun 15, 2005 | 08:59 PM
page62's Avatar
page62
If your block is good, go for heads and cam. Check my sig above for a suggestion on heads. I'd suggest a Comp XE268H or equivalent.
The 260hp engine ain't exactly a screamer...more of a good solid cruising engine. It's roughly equivalent to an L48.
To carb/intake setup
