Anyone running Blowers ?
Old Jun 16, 2005 | 01:25 PM
RoadrashOU812's Avatar
RoadrashOU812
Default Anyone running Blowers ?
Would like to see pics of any of ya's running blowers in there vettes . I am going to run a 671 and would like some ideas on fuel lines , linkage , etc...
Old Jun 16, 2005 | 05:03 PM
CGGorman's Avatar
CGGorman
PM Norvalwilhelm and Twin Turbo. I don;t think they check out C3 General, but they will have pics for ya...
Old Jun 16, 2005 | 09:54 PM
69vette66's Avatar
69vette66
Also check out big632. I believe his is a 14-71. His web site is big632.com
Larry
Old Jun 18, 2005 | 07:06 AM
RoadrashOU812
Yea , Ive seen Big632 vette before . It is definitely a Monster ! I had spoke with him about how the headlight holes had been filled in the past , was thinking of filling mine in as well .
Appreciate the info guys !
Old Jun 18, 2005 | 07:23 AM
norvalwilhelm's Avatar
norvalwilhelm
This is a 8-71 weiand blower on my 460
Old Jun 18, 2005 | 12:28 PM
RoadrashOU812
Thanks Norval,
Fine ride and I bet its a blast to drive . This is the tensioner pulley bracket I have with my Wiend 671 .It mounts around the harmonic balancer .... ofcourse it will not work because of the crossmember on the frame . Wieand told me they didnt have any other brackets , do you know who may that will work on my blower ? I am going to need a bracket similar to yours ...... up high .
Old Jun 19, 2005 | 11:50 AM
panchop's Avatar
panchop
this is the setup that came with my 871`BBC kit from summit. any reason you can't mount your idlear pully like that ?
Old Jun 19, 2005 | 12:29 PM
big632's Avatar
big632
Originally Posted by RoadrashOU812
Thanks Norval,
That bracket mounts around the blower snout not the balancer.On the pass side of the blower,bolted to the blower case.
Old Jun 19, 2005 | 01:39 PM
RoadrashOU812
I wish that was correct but no , it bolts to the front of the block right around the balancer . I pulled it off a friends engine in his truck .
Old Jun 19, 2005 | 01:42 PM
RoadrashOU812
Could you post a pic that shows me the bracket that holds the tensioner a little clearer ?
Old Jun 19, 2005 | 01:43 PM
RoadrashOU812
[QUOTE=panchop]this is the setup that came with my 871`BBC kit from summit. any reason you can't mount your idlear pully like that ?
Could you post a pic that shows me the bracket that holds the tensioner a little clearer ? What brand blower is that , mine is a wieand .
I am probably going to have to make a bracket to mount it just like yours .
Old Jun 19, 2005 | 02:03 PM
panchop's Avatar
panchop
unfourtunatley my camera is unavailable at the momoent. i bought this weiand 871 kit for BBC from summit racing .
the part number for my bracket , that goes around the nose of the blower is 7071 on my packing slip. that is for the unpolished bracket. I was told by weiand the diffence in the 671/ 871 etc is the leangth of the standoffs . if you add a P to the number it is for the polished unit. a call to holley will get you all the info on it.
greg
PS i don't know if it matters but this is for the 8mm belt system
Old Jun 19, 2005 | 02:41 PM
kanka's Avatar
kanka
hi Guys! I'am trying to put in a 454 with 6-71 weiand blower in my 78' . Can't you notch the frame and then weld in a gossit for strength to the frame? Also not to rob your thread but I would like to know if I can keep my a/c.ps. I aready have the sanden compressor for a.c. Any help please.
Old Jun 19, 2005 | 04:26 PM
norvalwilhelm
I can't see a bracket around the harmonic balancer?? I feel you are trying to mount it in the wrong spot. Weiand makes one bracket and it is the normal bracket that bolts to the blower up top. That looks like my bracket or very similar. I will have to take a picture.
Old Jun 19, 2005 | 04:46 PM
panchop's Avatar
panchop
there are a lot of differnt kinds of brackets. don't know if weiand makes them all but you can find many kinds out there. snout mounted, blower case mounted and block mounted. the picture you posted looks very like a picture i have of a mooneyham kit in my book ":street supercharging" . a quick look over ar www.blowerdriveservice.com would proably help you out on this one.
Old Jun 19, 2005 | 07:54 PM
RoadrashOU812
I wish ya were right but unfortunetely not . I am the one who pulled it off of my friends engine . The pic I have posted of it is exactly like it mounts to the block . There are two holes in the block on each side of the balancer , this is where it bolted to . The tensioner hung down low to the left . This came out of a 81 Chevy pickup truck so the crossmember of the frame was not in the way . On my vette , it will be .
Old Jun 19, 2005 | 08:04 PM
RoadrashOU812
Thanks Panchop .
I checked that site out but unfortunetly , there were no pics or diagrams to view ... so it was no help .
I sure wish that pic you last posted gave a better view of that bracket .
To Anyone running Blowers ?
Old Jun 19, 2005 | 08:53 PM
RoadrashOU812
Here is how this bracket and pulley mounted ( excuse the art work ) I tried atleast . Hope this picture is big enough to view .
Old Jun 19, 2005 | 08:57 PM
norvalwilhelm
How about just buying the bracket from wieand?? They would sell the normal bracket like I have and it just bolts to the blower.
Old Jun 19, 2005 | 11:00 PM
RoadrashOU812
Several months ago , I called the phone number on thier website and spoke with a supposed tech . He did not appear to be very well educated on wieand blowers but yet he was a tech ????
Anyways he told me there was no bracket for the tensioner to mount up by the drive for my blower . I told him that seemed odd but alrighty then . I figured I would have to make a bracket .
Hell , he could not even tell me how to determine what year model the blower was or where a serial number might would be to make sure it was a 671 .
