Rear Speaker
Old Jun 20, 2005 | 09:44 PM
71will's Avatar
71will
Default Rear Speaker
I haven't posted anything since about 1999, that's when I gave up restoring my 1971 Convertible. I now will restart where I left off....and if it becomes to much again I will sell it. Enough background,....
I remember seeing a thread on how to build a rear speaker "box" for a convertible (dimensions and supplies for 2 6x9's). Again I have a '71. Any info on where to find this info?
Will
Old Jun 21, 2005 | 01:21 PM
Todbo's Avatar
Todbo
i just built one for 71 vert , came out looking so good it looks factory
I know I've got the temp for it , I'll look around
Old Jun 21, 2005 | 04:49 PM
TARTAN2's Avatar
TARTAN2
Looks excellent
Dimensions and materials used would be great. Do you think there would be any difference for a t-top
Old Jun 21, 2005 | 09:40 PM
71will's Avatar
71will
that looks better than i've seen. if i could get the temp. GREAT!
Old Jun 21, 2005 | 09:52 PM
cosmicvette's Avatar
cosmicvette
Looks awesome! Nice job.
Old Jun 21, 2005 | 10:20 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Nice work. I'd like the template also.
Cheers,
Pete
Old Jun 21, 2005 | 10:32 PM
kdf1986's Avatar
kdf1986
Hello,
I would like to comment on the difference between the convertible and the T-Top.
For a T - Top there might be some obstruction with the removable rear glass holder on models up to the 72. For the 73 there should not be the panel under the back where the rear glass would sit into. This shelf stopped me from installing the same speaker setup in my 73 that I have in my 72.
just my 2 cents worth trying to be helpful.
kdf
Old Jun 23, 2005 | 07:38 PM
TARTAN2's Avatar
TARTAN2
Originally Posted by kdf1986
Hello,
kdf
Thanks KDF
Definitely worth knowing !!
Cheers
Old Jun 24, 2005 | 11:40 AM
Todbo's Avatar
Todbo
ok guys took some measurments , it just pressure fits in between wheel wells , it could be moved forward for the guys with t-tops if you have a place you need to store the tops. The carpet is from auto zone , glued it on with spray adhesive. this is the max size for the vert top to store correctly , I'm using the pioneer 5 way speakers , and pioneer head unit , no amp , and infinity speakers in dash , sounds great.
Old Jun 25, 2005 | 07:47 PM
TARTAN2's Avatar
TARTAN2
Will give it a try when I get back from holiday
CHEERS
Old Jun 25, 2005 | 08:45 PM
luerja's Avatar
luerja
Nice job!, Thank you for taking the extra time to do this for everyone.
Jim
Old Jun 29, 2005 | 09:32 PM
71will's Avatar
71will
Thanks for the temp.
To Rear Speaker
