A question about 700r4
Old Jun 25, 2005 | 01:53 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Default A question about 700r4
I have a 383 in a 82 with all the bells I could buy.(no computer). I'm geared down and have the trans. tricked out. I have a problem, tho. On the 82 you can not hold the trans. in low gear. The gate will only go down to L2. I think it's a gate problem. Is there a way around it? I would like to be able to shift from 1st to 2nd at my leisure sometimes. Thanks for any help. Larry
Old Jun 25, 2005 | 08:24 PM
dman535's Avatar
dman535
All you need to do is take a file and give yourself a little more travel in the shift gate. The cable, shifter trans - all that stuff will work just fine. Just need to modify the stop.
Old Jun 25, 2005 | 09:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
or you can buy the detent from BTO and put it in, that has the the 1st gear gate. the detent on the left is for the 700r4(with out the drill marks on i) is what you want to make your detent look like if you file it down. the other detent is for the TH350.
these are oriented as "mirror images"....with the "park detents" facing each other.
[IMG][/IMG]
Old Jun 25, 2005 | 11:03 PM
lebvette's Avatar
lebvette
Thanks alot. I knew you guys would come through. Larry
To A question about 700r4
