1) To all you guys who state "I tried xxx size tire, but it didn't work so I switched to xxx".
What do you do with the tires you've mounted, drove on and swapped out? Send 'em back? Or do you have ceiling-high stacks of barely used tires laying around?
I'm getting ready to order a set from Discount or TireRack, but not sure if they'll work (or look right). Can I return them? Will a local shop let me try on tires like my girlfriend tries on shoes?
2) What tire machine should a shop have for mounting tires on polished aluminum rims? Same for balancing...
Practically any shop will have the right equipment. Nowadays, even beaters have "bling" rims installed. So even the lowliest "south-of-the-border" shops around here have the right machines.
Unless your car is lowered to the max 255-60s will work fine.
My wheels are 17". I had 255/60/15's prior and they fit with slight rubbing. According to the tire-size calculator, an equivalent size is 255/50/17. However, when I posted that size previously, almost everyone says they won't fit.
