I have a 68-73 drivers side mirror that won't remain adjusted. The socket on the head is no longer tight on the ball of the mirror arm. I remember a good how-to this past winter on disaasemling a mirror and repairing it, but I can't find where I saved the article, nor have I had any luck using the earch feature.
Anybody have this how-to or know how to do the repair?
I believe that you have to replace the mirror & support - I dont think you can "fix" it.
I researched it a couple of months ago - several suppliers sell a kit with the mirrors that contains all of the necessary screws and rubber pieces and it can be done with out pulling off the door panel... http://www.zip-products.com/Corvette...81E1A65388A761
That said, I've super-glued them mine in place. Mirrors are still a few slots down the 'ol priority list .
Some may consider this a "Bubba" fix but it worked for me.
Remove the mirror and move the head to a position that's way off of correctly adjusted.
Lay the mirror face down on a flat surface with a towel or something under it.
Use a very sharp center punch and a small hammer to peen a few dimples in the pivot ball of the head. Make sure the locations of the dimples will be inside the mount when the head is correctly adjusted.
Start with a couple of dimples and keep at it until the head is tight enough.
Then reinstall and adjust the mirror.
I know this is crude but it worked with mine and lasted a couple of years. I am the only driver of my car so the mirrors are seldom moved. This 'repair' wouldn't hold up if frequent adjustments are made.
Soak the sucker in a closed container of laquer thinner overnight to dissolve the glue holding the mirror in place. Remove the mirror, exposing the guts behind. Use a rubber(or more durable material if you choose) gasket/o-ring/washer/whatever to shim the ball more snugly in it's socket. Re-apply the mirror with an adhesive of your choice.
Is that better?
YEP!!! This was it. I just couldn't remember how to get the adhesive to release from the back of the glass. Thanks!!!
