Just for fun...The worst sounds.........
Old Jul 18, 2005 | 10:10 AM
big_G's Avatar
big_G
Default Just for fun...The worst sounds.........
Let's discuss the worse sounds your Vette made that caused it to stop...
OK then..I'll go first.....BANG...SCRAPE.... I had a rear leaf spring end bolt brake...lol
Old Jul 18, 2005 | 10:26 AM
PhotoVette1's Avatar
PhotoVette1
Clump--scrap scrap--clang! As the right front brake caliper feel off on the interstate...
Old Jul 18, 2005 | 10:42 AM
71redskin's Avatar
71redskin
Default just for fun
except mine was right rear caliper
Old Jul 18, 2005 | 10:53 AM
Gordonm's Avatar
Gordonm
Crunch, grind, thump. Broke the ring gear off the carrier and everything came to a halt. I was picking up my ticket after a 1/4 mile pass. It totally let go pulling away from the booth. Fortunatly not at 100+ mph.
Old Jul 18, 2005 | 11:53 AM
rosslato's Avatar
rosslato
the disgusting sounds of a rod going thru the side of yer oil pan, still got nitemares of that
Old Jul 18, 2005 | 11:54 AM
71rdster's Avatar
71rdster
Wap, wap, wap, wap, wap......
Broken half shaft hitting the underside of the car.
Old Jul 18, 2005 | 12:01 PM
big_G's Avatar
big_G
We had a matching mumbers 69 350-350 come in on a flat-bed.
A hole thru the pan. I asked him (an 18 year old kid) if he heard any noise before it blew. He sais no. He had a 2,000 watt stereo!
Old Jul 18, 2005 | 12:05 PM
grayhook's Avatar
grayhook
the knock! knock! knock! of a piston rod!
Old Jul 18, 2005 | 12:24 PM
onaqwst's Avatar
onaqwst
sort of like a grrrrrrt,grrrrrrt ,grrrrrrrrt....... did this when ever i would go up or down an incline.... come to find out it was the rear bumper stop support on the t-arm that was hella bent down and when ever my half shafts was change angles, they would hit the support plate......
and then last week when i took the vette out of the first time in 2 years, i heard a kert, kert, kert.... it was my fan hitting my shroud due to a blown out mouter mount...
b
Old Jul 18, 2005 | 12:29 PM
MsVetteMan's Avatar
MsVetteMan
vrrmmmmm.....thump, thump, (harder) thump...........squeeelllllllllllll..... .....BOOOOOMMMMMMM.........CLANK, CLANK, CLANK............DAYUM!
Translation: accel. stuck, I'm beating the pedal with my foot, got on the brake very hard and was burning rubber trying to hold it, car backfired, then 1/2 shaft tore apart at left rear, me cussing........
Old Jul 18, 2005 | 01:55 PM
Rockn-Roll's Avatar
Rockn-Roll
Varoooom! Screeeeech! Varoooom! POP!!!
Peeled out of driveway in reverse...threw it in second and popped the clutch. Tranny was still in reverse due to the muncie design which keeps the reverse gear engaged if you're moving backwards even if you have shifted into another gear.
WAAAAAAAAAAAAAAAAAAA! Bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang, bang. Thunk! Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch. Crunch.
Did the stupid thing of going WOT on wet pavement...clutch packs just kept banging back and forth trying to get some traction until the clutch hub shattered. I looked back and couldn't see any parts on the road, but from the sound I expected my entire rear end to be in pieces spread out along the road.
Old Jul 18, 2005 | 03:45 PM
munday's Avatar
munday
turn of ignition next time., might diesel
Old Jul 18, 2005 | 04:27 PM
Stewart's74's Avatar
Stewart's74
Swipe....the sound of my Amex being used at the many Vette vendors........
Old Jul 18, 2005 | 04:42 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Old Jul 18, 2005 | 04:46 PM
72Tornado's Avatar
72Tornado
Thank goodness I haven't had anything as bad as some of these...I don't know which to call my worst though:
1) vr-vr-oo-m--vro--m-glug-glug--kk--v-ro--glug-glug-glug *engine dies*
My old Quadrajet needed a rebuild BADLY, had bad hesitation from a stuck float and the car finally died on the highway...
2) CLUNK!
After getting into my car and closing the door one night, the pin that holds the actuating rod from the outside door latch to the actual latch mechanism broke through - rod fell to the bottom of the door.
3) psssssssssssssssssssssss
Flat tire Something punctured it pulling into my garage the same night #2 occured!
4) thop-thop-thop-thop-thop
Second time driving on my full-size spare after #3, the tire popped off the wheel lip and made this rather unpleasant sound as it flopped around...
Old Jul 18, 2005 | 05:13 PM
fl_rider's Avatar
fl_rider
Default Momentary silence
1=Bang
8=Bang
4=Bang
3=Bang
6=Bang
5=Bang
7=Nothing
2=Bang
It's amazing what a flat cam lobe does, or actually doesnt do.
I must admit it did make the care shake in a sort of sickening way.
Old Jul 18, 2005 | 05:15 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
vro... BOOM.. clang da clang clang..
thud thud thud thud thud... (all the way home)
To Just for fun...The worst sounds.........
Old Jul 18, 2005 | 10:25 PM
glen242's Avatar
glen242
BANG. The sound of a ring gear bolt being locked solid between the ring gear and pinion gear.
My rear end rebuilder said the lazy, drug addled @#&! on the assembly line, during the late '70s, never put Locktite on the bolts, as required. He has seen a lot of these.
BTW, one of the loose bolts put a hole, in the cast iron cover, like it was shot with a .223 AP round.
Old Jul 18, 2005 | 10:26 PM
big_G's Avatar
big_G
Been there-done that
Old Jul 18, 2005 | 11:14 PM
Anubis76's Avatar
Anubis76
yep i know the feeling
and the assfolt in front of my house is still scared from that day
every time i see that huge scrape in the ground i get chills
