what's this for
Old Jul 19, 2005 | 01:28 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Default what's this for
I found a 2 prong sending unit on the right head between the number 6 and 8 plugs. Nothing was plugged into it. I looked through my repair manual, but couldn't find anything. Anybody know what this is for?
Old Jul 19, 2005 | 01:31 AM
SkunkApe's Avatar
SkunkApe
I believe that's a temp sender for the smog controls (EGR?).
Old Jul 19, 2005 | 02:40 AM
Twin_Turbo's Avatar
Twin_Turbo
The temp sender is 1 prong, the 2 prong is the temp switch (switches to ground) for the auxilary electric cooling fan, I'm betting the connector fell off because it melted due to exhaust heat and it's somewhere down near the frame rail
Old Jul 19, 2005 | 02:42 AM
Bangkok Dean's Avatar
Bangkok Dean
I somehow knew TT whould know that
Old Jul 19, 2005 | 03:44 AM
hoosiervette
Default whats this for
I don't have an aux fan. Yes I found the plug wrapped around the heater hoses. Can I just ignore this sending unit?
Old Jul 19, 2005 | 08:14 AM
Steve's74's Avatar
Steve's74
Depending on the year, this could be the temperature switch for controlling the TCS (transmission controlled spark) system that Chevy used in the early 70s. It had two prongs. The switch provided vacuum timing advance in any gear if the engine began to overheat. My memory isn't great, but it may also have added or removed vacuum advance under other conditions as well. And yes, the connector probably melted off.
Steve
Old Jul 19, 2005 | 08:26 AM
gerry72's Avatar
gerry72
Steve
Your memory isn't too far off. What the TCS did is to block vacuum advance until high gear while the engine was cold. The retarded timing made the engine warm up faster. Crude, but effective.
Old Jul 19, 2005 | 08:39 AM
RC73's Avatar
RC73
Depending on the year, this could be the temperature switch for controlling the TCS (transmission controlled spark) system that Chevy used in the early 70s. .
Steve
Kinda what I was think, need to know the year of the engine. Not all years had the same acc.
Old Jul 20, 2005 | 01:57 AM
hoosiervette
It's a 74 L48 with a 4 speed
Old Jul 20, 2005 | 07:13 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
What color are the wires? On the sensor and at the harness?
Don
Old Jul 20, 2005 | 07:31 AM
hoosiervette
I'll have to look. They are pretty toasted.
To what's this for
