I do the stupidest things sometimes Even without trying!! Even when I am being careful. I was reassembling my shifter today, putting the center console back together, and you know that little spring that goes on the shifter. I put it in the hollow shifter and it slips down to god knows where!!!! Fortunately, after about 10 minutes I was able to fish it out with a coat hanger. So the little lockout thingy goes on FIRST, then the spring, then the ****.... duh!
I guess i'm lucky. The spring is pretty much stuck in the ball. I've had that shifter off numerous times, and the spring has yet to move from the ball.
I almost did a dumb thing last night. I was prepping my new rebuilt trailing arms for the install. In my excitement I went ahead and installed the shock mount bolt without also installing the camber rod. I ruined the previouis shock mount bolts trying to get them out of the old trailing arms spindle supports. I was sitting there cursing the day I was born for doing this. Then I realized that I had greased the spindle supports where the shock mount bolt passes thru just incase I ever needed to remove them again. I grabbed a BFH and lightly tapped the shock mount bolt out. I ended up not embarrassing myself to much but it could have been bad if I had ruined another shock mount bolt.
ok , here is another one... this is something everybody does once, right? but once is enough, and then never again. But I have put a bend in a fuel line (or brake line) only to find both fittings on the wrong side of the bend! done it 3 times I think... ugh!
