Hooker sidepipes mufflers ??
Old Jul 21, 2005 | 07:14 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Hooker sidepipes mufflers ??
OK, the search engine found no matches.....
The Hooker mufflers are too restrictive, the JCL baffles too expensive.... does anybody have these installed ?
http://www.sweet-thunder.com/chamber..._corvette.html
I think the 2.25" ID should be loud enough and they should flow a lot better than the Hooker glasspacks (1 7/8" ID)... I'm curious how big the difference between the 2.25" and 2.5" ID mufflers is...
Old Jul 21, 2005 | 07:29 PM
PatsLs1vette's Avatar
PatsLs1vette
the sound clip of the 2 1/2's sound pretty good to me.
Old Jul 21, 2005 | 07:32 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
but it sounds like a pretty "wild" engine to me.... would like to know how it sounds on a 'mild' SB 350...
Old Jul 21, 2005 | 07:56 PM
73 LS-4's Avatar
73 LS-4
Hooker has come out with some new high flow mufflers, they probably don't show them anywhere yet. Since my car was down at Holley's R&D department as a test mule for the big block cars they gave me a set of the high flows and they do flow very well and they are pretty loud, this was about 6 months ago and I don't know if they are actually in production yet or not. My sig doesn't show the sidepipes that are currently on the car. If your interested you may want to call or e-mail holley and find out about the highflows, although I have no idea how much they cost.
Pat Kunz
Old Jul 21, 2005 | 08:02 PM
DaveWJunior's Avatar
DaveWJunior
6th Gear
Default On MAN!!!
I had enough trouble getting those darned inserts that came with the sidepipes IN ..... how the heck am I going to get the old ones OUT?!?!
Old Jul 21, 2005 | 08:22 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Pat Kunz
http://www.holley.com/products.asp?product=21046HKR
Summit has them now..........
Old Jul 21, 2005 | 08:53 PM
rosslato's Avatar
rosslato
wheres theres a will theres a way. i had to do mine twice but i've got CRS
Old Jul 22, 2005 | 01:51 AM
Z-man's Avatar
Z-man
Originally Posted by yellow 72
Well, in another month...
Anyone have these??? They have a full 3 inch flow through for Hookers.
http://www.classicchambered.com/
Old Jul 22, 2005 | 02:56 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I've made up a pair using what Summit used to sell called Turbo Tubes, basicly a chambered muffler, and they were freakin' loud!
The Hooker Max Flow with a perforated core will have a deeper mellower sound.
If you can do a little fab work, the Dynomax Magnum glasspacks have the same core and are dirt cheap
To Hooker sidepipes mufflers ??
