Alright , I'm stumped . I have a very hard to turn problem like there is no power steering .
The P/S pump , hoses , centering control valve and lines are all new . The only thing that I have not replaced is the cylinder underneath the car . Would this be the problem ?
When you lock the wheels to one side (with the eng. running), does the pump make noise? If so, it's possible the ram is bad, but if no pump noise, the new pump may have a problem...G/L
The Ram is the only P/S part that hasnt been replaced , this is the part I previously stated hadnt been changed .
Would this cause the car to act like it had no P/S ? The wierd part about it all is a year ago when the car was running with the old engine , the P/S worked fine . Is it possible the valve in the rear of the P/S pump is stuck ?
After turning it lock to lock,check pump temp (engine running).Generally,pump temp should be around 155-160 degrees F...if you are at 200 F,that is a problem...
If air (bubbles) were in the line , wouldnt it be growling ? Also .... the car has made 5 road trips , surely this would have worked the air out of the lines .
I only saw the directions once for a cadillac. Turn lock to lock to bleed system. I'm thinking its all new and might not growl since there isn't any pumping function, it don't power assist.
Driving isn't the same thing, the directions did say lock to lock.
Gonna raise the front end and try the lock to lock thing . Hope this cures the problem . If not ..... the new pump could be bad like big_G said .
I appreciate all ya's help ! Just wondering if that ram would cause this as well . I sure hate swappin parts but sometimes thats what it takes . Got a lot of horsepower now and with it acting like manual steering , it sucks ! Hard to control this baby .
Well , the lock to lock deal didnt work out to fixing the problem .
This doesnt make since . A little over 1 1/2 years ago , I replaced everything except the ram . The power steering worked fine . The engine went down so I pulled it , the p/s system was never opened in any way .... just layed the pump over to the side . Now wth the new engine , it wont work .... like manual steering !
The plunger with the spring in the back of the P/S Pump must be stuck !
This has to be the problem .
Alright ... wheres all you people with the brains ?
Here is somethingelse I noticed . If I adjust the toe end a little to the positive side , the steering is easy (normal) either direction . But when I adjust the toe end back to zero degrees , it is hard to steer to the right but easy to the left . Something is really strange !
I am trying to understand the theory behind the C3 vette power steering .
Not enough pressure. I just replaced mine with a rebuilt, turned out to be a lemon. #3 worked like a charm. Mine would only turn easy with higher rpm's, as soon as the r's came back down to normal it was hard steering again.
In addition to big G adjustment comment you should consider flushing system and adding new fluid....
I assume no noises from pump..so that means there was no air in system,otherwise you would have heard a buzzing sound...so, it could be a valve hanging up...ie,no/little flow to one side...
another thing...you can check for control valve adjustment by getting front wheels up,centering steering wheel,and running engine...if steering wheel turns on it's own right..or left,your control valve is out of adjustment...
I learned this much after going up in smoke at 75 mph when my "out of adjustment" control valve blew a pressure line out of it's fitting...but,I had no "hard steering" symptoms prior...
Thanks guys , its a new centering valve but that doesnt mean its adjusted right . I will adjust on it and see what happens .
No , the wheels dont drift to one side or the other when raised off the ground so the centering valve has to be close.... but then again it came from ecklers so it may not be any good . I have gotten a whole lot of junky parts from them in the last year . They are just not the same as they were years ago .
I will keep trying , its gottta get fixed before its over .
Well after P/S Pump # 3 , still have the same problem . The Problem is not in the pump . It has to be either the ram or the centering valve ( which is supposedly a new one from " Ecklers " ) .
