Why in the world am I still leakin oil at my fuel pump...
Alrighty then.. I've had a oil leak problem at the fuel pump on my 327 since I rebuilt the motor. I thought I had fixed it until I got home today and found oil all over the passenger inner fender... It must have really been under pressure when it first blew thru my gasket. Three weeks ago I pulled the pump but not the plate and cleand the pump and the plate up. Cut me a new gasket out of gasket material and applied Permatex #2 to both sides of the gasket and re-installed... All was well until today.. Just wonder what I did wrong or a better way to do what I've have already. Thanks guys... Dave...
Originally Posted by cooter69
check the short bolt on the front of the block that holds the pump shaft up when changing the pump.
#2 is non-hardening but I didn't use a lot on it just enough to smear around with your finger on both sides...
Originally Posted by big_G
Maybe it's coming out of the timing cover? Tell me it's not chrome.....
Is a problem I had also ...... damn chrome timing covers are bad about leaking for sure !
maybe the fuel pump is shot ???? look very close ,i bet you find your own problem
FYI...a tool we use ALOT is a black light that uses a dye you add to fluid, like oil...Autozone has the kit for about $80..you can use the light on any fluid leaks...put the dye in with a little oil and run the vehicle for 5 min. or so and shine the light where the leak was,,you will find the source..
Location: Las Vegas - Just stop perpetuating myths please.
There should be no pressure inside the pmp mount casting.
That pmp casting mount has a drain straight to the oil pan. If u have pressure there then ur PCV does not work and u have crankcase pressure too. If u don't run a PCV then u at least need a breather on the vlv cover or intk to vent the crankcase and release piston blow-by press. Ur lucky thats the only "leak" u have.
Again u should have no oil pressure behind that fuel pmp plate or in the crankcase - only within the oil galleys. PCV should maitain < atmospheric press (vacuum).
cardo0
