newbie with a wheel question
Old Jul 25, 2005 | 11:34 AM
m1tommygun's Avatar
m1tommygun
Default newbie with a wheel question
I have just purchased my first Corvette about a week ago. It is a 1976 stingray L48 (according to the vin number). I do not know much about what the previous owners did to it, but one thing that was done was when it was re-painted they had the aluminum wheels painted to. I want to remove the paint. My father has an enclosed sandblaster, and I thought about sandblasting the paint off then glass bead blasting them to shine them up. Will this work, or do any of you all have any suggestions or ideas? Thanks.
Scott
Old Jul 25, 2005 | 02:10 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The surface will look like &^%$ after sandblasting - use paint stripper, that should get all the paint off.
the stripper won't hurt the aluminum unless you leave it on there for a week
After stripping use 400, 600 and then 1000 grit sanpaper (1000 wet) and chrome polish... here's the "result":
Old Jul 25, 2005 | 08:18 PM
fl_rider's Avatar
fl_rider
Default Definitely dont sandblast!!
Strip the paint and then sand and polish them.
It is worth all the effort.
Old Jul 26, 2005 | 05:12 AM
m1tommygun's Avatar
m1tommygun
Thanks for the info. I will try the stripping and sanding method instead of the sand blasting method.
Scott
To newbie with a wheel question
