broken rear wheel stud
Old Jul 26, 2005 | 10:31 PM
manco10's Avatar
manco10
Default broken rear wheel stud
Does anyone know if you can replace the rear wheel lug stud bolt with out removal of spindle? I have the caliper and rotor off it looks if you remove the E brake there might be room? I thunk the rear spindle is pressed? in Don't think I can tackle that. Thanks D.
Old Jul 26, 2005 | 10:36 PM
big_G's Avatar
big_G
Yes you can. Take out the adjuster, rotate the broken stud to the 6 o'clock position, pop out the old and put in the new....G/L
Old Jul 27, 2005 | 08:13 AM
manco10's Avatar
manco10
Thanks for the advice. Will try tonight. Thanks D.
Old Jul 27, 2005 | 08:28 AM
two-drop-tops's Avatar
two-drop-tops
Do you know if this works for all C3's or just certain years?
Old Jul 27, 2005 | 09:23 AM
big_G's Avatar
big_G
All C-3's
Old Jul 27, 2005 | 09:34 AM
norvalwilhelm's Avatar
norvalwilhelm
All C-3's
I do not have the backing shield and installed all new 3 inch long studs using the 3 oclock on the passengers side and 9 on the drivers side.
Old Jul 27, 2005 | 01:57 PM
manco10's Avatar
manco10
Bought a new stud today it is 1/4" to long to fit. I have a dust shield on the back. Is ther any way around this???? Thanks D.
Old Jul 27, 2005 | 02:03 PM
big_G's Avatar
big_G
If it is longer than stock length, you may have to rotate the spindle to a location that allows the dust shield to move more...or grind a few threads off the new stud to match the original one.
Old Jul 27, 2005 | 10:58 PM
lostpatrolman's Avatar
lostpatrolman
You can always drill a hole in your dust shield
To broken rear wheel stud
