To AC or NOT
Old Jul 26, 2005 | 10:48 PM
Code Blu's Avatar
Code Blu
Default To AC or NOT
Just wanted to get some opinions on AC for my 77 vette. I have all the AC parts in the car but, the belt is off and has been off for over 5 years. Also a light green wire has been cut. With the system not working for that long would most of it need to be replaced (compressor, condensor etc.)?
I have been seriously thinking of removing the entire system. The engine is not original and I am not interested in restoring to original specs. Just want to get some opinions.
Old Jul 26, 2005 | 10:53 PM
RC73's Avatar
RC73
I guess it depends on were you live. Here in Texas, A/C is a must, at least for me. It get hot as here.
Old Jul 26, 2005 | 10:58 PM
Code Blu's Avatar
Code Blu
I live in Oakville, Ontario Canada its hotter than ..ll right now but, it is not normal.
Old Jul 26, 2005 | 11:34 PM
RC73's Avatar
RC73
Well, It get hot here every summer, so most people want/need a/c.
So it really a judgement call on your part. If this is not a typical summer for you, you may just wants to live with the heat for this year, it does use more fuel and some HP. I have lived through some hot summer here without a/c in some past cars that I had and after a couple of summers they had to go. But if I lived somewhere where the weather was nice 99% of the time, I could live without it for one summer. That just me.
Old Jul 27, 2005 | 12:11 AM
Empatho's Avatar
Empatho
take it all out
Old Jul 27, 2005 | 07:38 AM
Ganey's Avatar
Ganey
... If this is not a typical summer for you, ...
But if I lived somewhere where the weather was nice 99% of the time, I could live without it ...
It's good that it is not as hot as usual. If you ever want to sell the car in S. Texas for a good price- leave the A/C in! W/O A/C- good luck!
You can expect the compressor is bad which is why the belt is off. If the system is still sealed, it may only need the compressor & wire to it fixed.
If I lived where it was not needed, would remove it.
Old Jul 27, 2005 | 08:24 AM
Pete76Shark's Avatar
Pete76Shark
I agree with Ganey except that I would get it working even if it was not needed, for the re-sale opportunities. I bet the compressor is bad and if so DO NOT get a rebuilt, get a new one. Hope this helps
Old Jul 27, 2005 | 10:05 AM
Z-man's Avatar
Z-man
All Vettes come with 2-40 air conditioning anyway!!!
Old Jul 27, 2005 | 10:12 AM
markdtn's Avatar
markdtn
If it is basically all there I would fix it.
Old Jul 27, 2005 | 10:35 AM
holley505's Avatar
holley505
update to new freon... which means new pressure fittings in the entire system including new receiver/drier/orfice tube and new style oil.
Old Jul 27, 2005 | 10:36 AM
C3nMe's Avatar
C3nMe
I also have a '77 where all the stuff is in the car, and the belt is on the compressor -- but I expect it is out of refrigerant.
Which compressor is supposed to be preferred -- the short one or the long one (I can't recall which is called the A4 and which the A6)
I am also thinking that to restore it to operation, I would change it over to a 134a type application since R12 is getting more expensive and harder to get. I've seen kits of seals and so forth for the conversion -- but I would have it done.
Anyone attempted that and have an idea of what it would set someone back?
Brian.
Old Jul 27, 2005 | 10:48 AM
Pete76Shark
Brian.
During the 1976 model year they switched from the Axial A6 (long) compressor to the Radial (short and round) compressor.
So if you are looking at a stock 76 it could have either compressor and still be stock.
In 1977 they should all have the Radial compressor.
I am not sure which one is better but I know the A6 pumps like there is no tomorrow.
Old Jul 27, 2005 | 10:51 AM
Bob Turner's Avatar
Bob Turner
I would look into an aftermarket setup from VintageAir and modify it for your '77. I've watched my father-in-law spend close to $1,000 over the last 4 years trying to keep his WEAK factory R-12 a/c system going....
Bob
Old Jul 27, 2005 | 10:55 PM
Code Blu's Avatar
Code Blu
Thanks for all your replies. I'll think about it some more but, I am leaning towards removing all of it. Even if I did get it to work I have heard that it is really not that good. Installing an aftermarket one would be something I might consider but, way in the future. I would sooner put the money into the drivetrain.
Again thanks guys I appreciate all your comments and valuable information.
Old Jul 28, 2005 | 08:06 AM
Ganey's Avatar
Ganey
Actually the A/C is fine!
I also have a '77 where all the stuff is in the car, and the belt is on the compressor -- ...
Which compressor is supposed to be preferred -- the short one or the long one ...
Brian.
A/C Compressors
A6 The long A6 is considered by A/C experts to be an excellent compressor.
-Large & heavy- not what one wants in the design requirements for a high perf. sports car.
R4 +Light, small & out of the way.
It is possible to put in a small light compressor that uses less HP
like a ND or Sanden.
Sanden +Uses less HP, light & small. Said by A/C experts to be noisy & not as high quality as the ND.
ND 6P +Uses less HP, light, small, quiet & excellent reliability.
This shows a ND 6P. Note how the A/C lines are run off to the side & then forward & back.
http://ganeys.home.sprynet.com/77ACs.JPG
Old Jul 28, 2005 | 11:26 AM
C3nMe's Avatar
C3nMe
For some reason, I am still inclined to get the A/C working ...of course, I doubt there is a lot I can do myself, as I don't know the condition, and I have no tools for diagnosis.
I understand the statement about the high performance car stuff ...but there are times when I'm just driving, and not pulling .8Gs on the skid pad -- might as well be comfortable those times. (not to mention, it helps ease things with the wife )
Old Jul 28, 2005 | 11:30 AM
Hef's Avatar
Hef
Default ac works
My vote would be to leave it in - mine was not used for 10 to 12 years and I tried it the other day and it worked great. Its espcially nice when you want the windows closed.
Hef
To To AC or NOT
Old Jul 28, 2005 | 11:45 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
rip it out. I did. Not worth it for the few weeks it gets really hot.
come to think of it i never really used it when i was in Louisiana because the engine would overheat.
Old Jul 28, 2005 | 01:02 PM
SharkAttack's Avatar
SharkAttack
I try to consistently make mine 2-80 or more!
Old Jul 28, 2005 | 05:15 PM
Pete76Shark
Code Blu nobody on this forum can tell you what to do on this.
It really is a matter of your personal preference.
If while drive your Vette around town or whatever you notice that the skin around your ankles is on fire then you might decide to keep the A/C and get it working.
If while driving around town you dont notice any cockpit heat issues then you might decide to rip it out.
I did what was right for me as the other members who commented here have done. The cockpit heat was to much when I lived in New Jersey so when I moved to South Carolina it was a no brainer to keep the A/C in tip top running condition. And when I want to get on it I just reach up and cut off the A/C..
If you decide to keep the A/C then you get into can you do the A/C work yourself or do you have to pay a guy to do it. This is not cheap either way.
Whatever you decide Code Blu is right for you. Good luck to you and like they say
Happy Motoring
