Magnetic Drain Plug from Ecklers
Old Jul 30, 2005 | 12:56 AM
StingRay327's Avatar
StingRay327
Default Magnetic Drain Plug from Ecklers
A while back I got a magnetic drain plug from Ecklers I believe it was, and it came with a plastic washer on it. I left that washer on thinking it needs to be there and now it is just a warped mooshed piece. Am I not supposed to have that plastic ring on there? My original drain plug didn't have anything, just metal to metal. What'd anyone else do with their's?
Old Jul 30, 2005 | 01:11 AM
RC73's Avatar
RC73
As best as I dan remember, I have a metal washer on my drain plug, I belive it copper. Just changed the oil a couple week back so it will be another couple month before I change it again to take a look at it.
The plug should have a washer though. I don't think a plastic washer would last very long with the heat from the pan and exhust.
The copper wahers are called copper crush and should be changed each time you change the oil, but I have reused my over many times and no leaks.
Old Jul 30, 2005 | 03:09 AM
Twin_Turbo's Avatar
Twin_Turbo
If you don't have a new copper washer just heat your old one red hot and let it air cool to anneal it (make it soft again)
Old Jul 30, 2005 | 06:09 AM
Frankenvette's Avatar
Frankenvette
You can buy a pack of 5 washers, either copper or aluminum, from most autoparts stores for a few bucks. I justed purchased some copper ones a few days ago for both my cars.
Old Jul 30, 2005 | 01:06 PM
StingRay327
Sounds good! I didn't know any of that. Thanks
To Magnetic Drain Plug from Ecklers
