I have to set the idle on my new 383 to 1600 in park so it will idle at 800 in gear. it has the factory torque convertor 1981 / turbo 350
with lock up. will a 2500-3000 stall convertor affect my idle speed? I hate for it to idle that fast in park. cam powerband is 2500-6000
A stall converter will not pull the idle down as far when put into gear....so the answer to your question is yes. With my 2800 stall converter my idle is around 1100 in park and 800 in drive.
From: San Diego - Deep Within The State of CONFUSION!
If you have that much of a differential between gear and park idles, I wonder if you have a vacuum leak>?
My 383 has a mild cam but that's not why I chose to get a stall convertor...I just wanted it to take off outta the hole like a Vette should. At low RPM the convertor just slips, so it can't affect your idle speed.
A correct converter with a solid lifter engine should idle at around 800-850 rpms both in and out of gear. With a hydraulic cam, 600 would be acceptable both in and out of gear.
I believe this in regards to an auto, not a manual tranmission. I never seen an auto that did not decrease in rpm when it was put in gear.
I'm not sure why lifters would have any affect. When it is put in gear, the tranmission puts some stress on what was a free wheeling engine. That's why you got to put your foot on the brake. Putting some stress on the engine will cause it to drop in rpms. A higher stall converter will slip more at lower rpms allowing a decrease between the idle speed in nuetral and the idle speed in gear.
It`s that a solid lifter engine normally requires a higher idle than a hydraulic. A higher stall {or flash point} converter is required to maintain the constant idle in and out of gear and was the "correct" converter that I was refering too whether solid or hydraulic. It`s very annoying to have to keep one foot on the brake and the other on the gas pedal trying to overcome a low RPM converter.
