How Do I Install New Vent Balls
Old Aug 8, 2005 | 07:42 PM
KYBRIGGS82's Avatar
KYBRIGGS82
Default How Do I Install New Vent *****
I ordered new vent ***** with felt for my 68' bb roadster. How do I install these without making a mess and tearing apart something I don't need to break??
Old Aug 8, 2005 | 07:56 PM
rcread's Avatar
rcread
I was cleaning my interior yesterday and was wondering the exact same thing.
Old Aug 8, 2005 | 08:04 PM
PhotoVette1's Avatar
PhotoVette1
The passenger side one is a breeze--just take off the right hand dash.
The left one--well--let's say I would rather change the motor in the rain.
Old Aug 8, 2005 | 08:05 PM
KYBRIGGS82's Avatar
KYBRIGGS82
Well I guess I'm not the only person who has no clue on how to replace the ventilation ***** and has a concern on breaking more parts !!
Old Aug 8, 2005 | 08:08 PM
PhotoVette1
I replaced mine. The dash panels have to come off. No buts about it. The driver side is a real PITA.
Old Aug 8, 2005 | 08:19 PM
KYBRIGGS82's Avatar
KYBRIGGS82
I figured with the ventilation ***** being inexpensive to purchase the real chore was the time involved in replacing them..BUT how do you replace them ..step by step would be helpful..I'm about as mechanical as a parolee attempting to pass the bar exam with only a prison education !!
Old Aug 8, 2005 | 09:56 PM
lostpatrolman's Avatar
lostpatrolman
There is a plastic cup looking plate that bolts onto the rear of the dash. It straddles the ball and should have some stick on felt to keep the ball vent from moving around. Once you look behind, you will see how simple it is.
Old Aug 8, 2005 | 10:04 PM
big_G's Avatar
big_G
I have done the drivers side without removing the dash. Loosen it at the door jamb and remove the 2 steering column support bolts (9/16 inch?) to allow the pad to pull out a little. If you have air cond., remove the left duct assy. Get a small flashlight, peek in and locate the three retaining screws.(Phillips). Remove the screws, retainer and the ball. You may not wish to replace the felt, as I have found the thickness to be too much. This is much quicker and safer than removing the dash, IMO...G/L
Old Aug 8, 2005 | 10:28 PM
jbroughton's Avatar
jbroughton
They can be popped in and out from the front of the dash! No dash removal necessary. They are not exactly round, and if you turn them a certain way, they will pop out. Somebody told me this and I didn't believe him, but sure enough, they came right out! I don't remember exactly how I turned them, but once I did it was a piece of cake. 5 minute job!
Hope that helps,
Jeff
Old Aug 8, 2005 | 10:31 PM
big_G's Avatar
big_G
Maybe only if the front ball retainer is broken!
Old Aug 9, 2005 | 10:18 AM
jbroughton's Avatar
jbroughton
Hmmm, didn't see anything broken. All I know is that both of them popped out very easily when I got them turned to the right angle. And while everybody else was dropping their steering columns and dash pads, I was out cruisin' with shiny new *****!!
Old Aug 9, 2005 | 11:05 AM
Glassbowtie77's Avatar
Glassbowtie77
Hope that helps,
Jeff
That's how I did mine, the ball retainers were not broken before or after I did them either.
Old Aug 9, 2005 | 12:19 PM
7d2 vette's Avatar
7d2 vette
sounds pretty ballzy to me!!!!
Old Aug 9, 2005 | 09:35 PM
DZRick's Avatar
DZRick
Ballzy or not that's how I did mine.
Almost positive I read in one of the vette mags that this was possible.
I would'nt have dreamed of doing it otherwise.
I first tried it on an old dash pad and it was so easy to do.
5 minutes later my car was done, nothing like nice shiney vent *****.
Rick
Old Aug 9, 2005 | 10:15 PM
fast idle's Avatar
fast idle
swapped mine from the outside too.
Old Aug 9, 2005 | 10:39 PM
big_G's Avatar
big_G
Well, while I'm not into pulling *****, I'll give it a try...l
Old Aug 10, 2005 | 01:08 AM
kend414's Avatar
kend414
Remember, it's not what you have under the hood that counts, it's what kind of ***** you have!
To How Do I Install New Vent Balls
Old Aug 10, 2005 | 06:27 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
They'll pull out from the front. Pop the new ones in. Chuck
Old Aug 14, 2005 | 07:23 PM
KYBRIGGS82's Avatar
KYBRIGGS82
Default Installing Vent *****
Ok..thanks..turn The Vent Ball Sideways With The Solid Part Of The Vent Showing. Make Sure The Wide Side Is Facing You And Gently Pull Or Adjust Until The Vent Ball Pulls Out.. 2 Vent ***** Out And Installed In Less Than 5 Minutes..thanks Everyone
Old Aug 14, 2005 | 08:00 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Hmmm.. I'll have to ask my wife... "HONEY" how did you change the vent *****
Glad you figured it out, you would want to hear her answer
