What are the differences between the L82 and L48 engines? Specifically those from the late 70s Vettes. Obviously the L82 makes more power, but I'm wondering how it makes that extra power. More aggressive camshaft? Freer-flowing heads? Sorry if this is a dumb question, I'm new to C3s.
Also, what would it take to make an L48 put out equal power to an L82? Is there any particular modification that really wakes these engines up (headers, carb, etc)? How reliable is each motor?
What are the differences between the L82 and L48 engines? Specifically those from the late 70s Vettes. ...
I am going to try and upgrade my L48 to something like the L82. I'm talking to all the engine guys I know and the plan is formulating. Corvette Fever March 1996 and April 1996 did a two-part article on raising the hp of the L48 from 190 to 326. I don't think I need all that HP. I plan to incorporate part of what they did. (1) Pistons rods and crank will stay the same. (2) Crane cam, probably the HMV272-2. Comp cams have a nasty tendency to wipe a lobe. (3) Dart cast-iron heads with 2.02/1.60 valves. (4) Aluminum high-torque intake manifold (that fits under my 1973 hood (I have not found many options here, I may need to go with the late C3 Aluminum intake), (5) the 2.5 inch ram-horn exhaust manifolds from the 1965 327 corvette. (6) Some type of improved distributor perhaps the HEI. I'm attempting to keep a stock-looking engine compartment for the autocross inspectors. A local engine guy runs a drag car with 500 hp in a two-bolt main. He claims the two-bolt is reliable enough for what I want to do. The 2-bolt and 4-bolt castings are the same. The bearing caps can be modified for 4 bolts if higher hp or stroker kit is anticipated. Just my $0.02. Appreciate hearing what others are doing to work around the L48.
