'A' Pillar Damage?
Old Aug 17, 2005 | 07:15 AM
spitfireal's Avatar
spitfireal
4th Gear
Default 'A' Pillar Damage?
Hello all,
Looking for some words of wisdom on the 'A' pillars of a car I looked at the other day on behalf of a friend.
It's been a while since I've looked at a C3 but I don't remember the 'A' pillars looking like these (see below). Something doesn't look right.
Any thoughts???
Thanks,
Al
Old Aug 17, 2005 | 07:18 AM
Graemeinvette's Avatar
Graemeinvette
Ouch, the dreaded Bird cage rot!!
Old Aug 17, 2005 | 07:54 AM
markdtn's Avatar
markdtn
Rots of rust. Figure what you can't see doesn't look much better. People will probably tell you it's a parts car now, but just figure the cost of replacement into the price of the car.
Old Aug 17, 2005 | 09:27 AM
wills670's Avatar
wills670
This is what you will probally find when you get in their.
Before I started to repair my birdcage it did not look as bad as the pics. you posted.
Looks like it is going to be in bad shape behind the fenders.
Old Aug 17, 2005 | 10:13 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
The paint looks pretty good from what we can see too bad that won't hold the windsheild in it looks like there will be a fair amount of work there.
Old Aug 17, 2005 | 11:47 AM
CMYC4GO's Avatar
CMYC4GO
RUN, don't walk!
Old Aug 17, 2005 | 01:20 PM
Scottys78's Avatar
Scottys78
that looks pretty bad. Going to need a good amount of work
Old Aug 17, 2005 | 05:53 PM
spitfireal's Avatar
spitfireal
4th Gear
Thanks for the great reply's guys.
It is obviously worse than I thought. Can anyone post a picture of what it should look like there?
The "holes" that are visible in my pics - I thought that was fiberglass there. Am I wrong? Is that steel there?.
Thanks,
Allan
Old Aug 17, 2005 | 06:04 PM
Twin_Turbo's Avatar
Twin_Turbo
the sections with the holes is not really structural, it's a sort of metal flap on the side, but it's not fiberglass. What lurks under the fiberglass cover on the pillar itself and under the bonding adhesive is what could be really nasty. This pic may help to clear up what's fiberglass and what not, disregard the cage nut hanging on the pop rivet there, it's not supposed to go here. You can see where the (aint stripped) fiberglass pillar covers go (they are there sitting in place)
Old Aug 17, 2005 | 06:08 PM
70inSBIn's Avatar
70inSBIn
mine actually had bondo there that somebody tried to smooth out and fill the space up into the underside of the fender. Its amazing what DIY'ers do over the years to these cars. The problem on mine was the fenders want to flex or expand different than the steel, and so the bondo cracked. I just ground it all out and sanded smooth. Looks good now.
I thought the actual "half moon" holes were supposed to be there. Mine has those, but the whole thing just looks smoother. Id take a pic, but I have new weatherstripping in that goes in that area. It looks like the steel has bubbles pretty bad in your pics.
I'd also like to see some pics of that area. Now Im curious what others look like.
Old Aug 19, 2005 | 06:07 PM
70inSBIn's Avatar
70inSBIn
can somebody put up a pic of the area shown damaged above, but as its should look correctly (in a similar view without the weatherstrip in place)?
To 'A' Pillar Damage?
