Wheel Spacer/Adapter
Old Aug 18, 2005 | 08:14 AM
Wuttin's Avatar
Wuttin
Default Wheel Spacer/Adapter
Hi all,
I was fortunate to receive a new set of custom rims with my '79 that I attempted to have installed. The manager told me the offset was wrong and he could not/would not install them. I researched it and it looks like I can add spacers to decrease the offset. The wheels are 5 X 120.7mm, 7" width with a -13mm offset. Any idea how large a spacer I would need to safely do the job? Spacer vendors? How would this affect the handling? I know stock rims are 8" width but I don't know the offset. Any advice appreciated?
Thanks,
Wuttin
Old Aug 18, 2005 | 08:26 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It's not only the offset ... the rim's spokes may hit the brake calippers. Your offset is -13mm (roughly 1/2") ... with a 7" wide rim that's about 4" backspacing which is ok....
To determine your spacer/adapter size:
Mount the rim with washers between the rim's mounting surface and the axle's hub (car must be on jacks of course) and see what it takes to get the rim on there without hitting anything.
Old Aug 18, 2005 | 09:07 AM
Wuttin's Avatar
Wuttin
Thanks...apparently the rim would fit on the hub without hitting anything but it came within 1/8" of the brake lines but the calipers were clear. With the tire mounted it would surely hit. It would seem to me a reasonable spacer (1/2"??) would solve the problem. I was surprised by the shopkeepers reluctance, essentially because he thought it would really impact the handling.
Old Aug 18, 2005 | 11:23 AM
Wrencher's Avatar
Wrencher
Default Try these guys
http://www.markwilliams.com/
These guys sell a variety of top quality billet spacers. The wheel shops see too many low quality pot metal spacers and won't accept the liability associated with using them. I run a set of 1/4 spacers on my BOSS 302 running a Coleman 4-wheel disc NASCAR setup that allows me to use the stock 15" Magnum 500 rims and 13 1/2 inch rotors. This setup has seen many laps of road course work with no problems.
Good luck.
Hans
Old Aug 18, 2005 | 10:48 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Good luck.
Hans
there's a TON of junk and garbage spacers out there..... many are high quality and fit like a glove. I bought some on Ebay and these are really good. That seller is "completevalue" - two 1" adapters are about $80.
Old Aug 19, 2005 | 11:59 AM
Frankenvette's Avatar
Frankenvette
I also purchased my 2.5" adapters from completevalue per Redbad1979's recommendation. These babies are very nice. To bad I have to cover them up with the wheels. They are also both hub and wheel centric which I feel more comfortable with.
Old Aug 19, 2005 | 12:45 PM
waltd79's Avatar
waltd79
5th Gear
Default Spacer
Don't forget to check your stud length - Stock length may be to short, after you add a spacer. I have some 10" wide rims, with a 4" offset, had to get 1/2" wide spacer plates made, to clear calibers. Ended up going to 1/2" race type studs.
Old Aug 19, 2005 | 01:14 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Good luck.
Hans
Didn't know they had spacers.. I was looking for a while for quality spacers... Just ordered the billet aluminum 1/4 inch spacers
Old Aug 19, 2005 | 01:42 PM
Twin_Turbo's Avatar
Twin_Turbo
Hey..that's excellent..they have what I need also, just need some reducer bushings since I have 1/2" studs and not 11/16 (just checked and they have those also...excellent )
Old Aug 19, 2005 | 02:20 PM
GrandSportC3
Got a voice mail from Mark Williams Enterprises that the spacers aren't in stock and it'll be 1 - 2 weeks before they'll ship..
I'm not in a hurry..so that's ok...
Old Aug 22, 2005 | 01:21 PM
Wuttin's Avatar
Wuttin
Default Thanks
Great advice and links..couldn't have asked for more.
Wuttin
To Wheel Spacer/Adapter
