having overheating problemswith my 78'need help?
Old Aug 22, 2005 | 03:15 AM
strokergw's Avatar
strokergw
1st Gear
Default having overheating problemswith my 78'need help?
just instaled new 350ci short block.boiled out raidiator,new flex fan,fan shroud,thermastat,hoses,tryed everything i can think of.anyone have somthing i have'nt tryed.please i'd like to hear it. strokergw
Old Aug 22, 2005 | 07:19 AM
fl_rider's Avatar
fl_rider
Default Lower radiator hose??
Check your lower radiator hose to see if it is collapsing. It might need a spring inside of it.
Is all of the air out of the cooling system?
Is all of the foam in place around the radiator?
Old Aug 22, 2005 | 03:33 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
you didn't say, does it overheat while idleing in traffic, or while cruising at/above 55 mph?
Old Aug 22, 2005 | 03:46 PM
Anubis76's Avatar
Anubis76
do you still have your windown under the front end of the car?
does the car start to cool back down when you start to drive non stop?
Old Aug 22, 2005 | 04:32 PM
rihwoods's Avatar
rihwoods
Front spoiler.very important...
Rad seals...
Flex fan ??? I think stock setup better with thermal clutch...
Size of Rad ?...Standard or Heavy duty...need Heavy duty with A/C...
Old Aug 22, 2005 | 06:06 PM
Chopper Larry's Avatar
Chopper Larry
I'd make sure the "seal" is present between the condensor and radiator. Get a 160 degree thermostat too. A new motor should run a little hotter also.
Old Aug 22, 2005 | 09:49 PM
CrossedFlags77's Avatar
CrossedFlags77
Is it overheating at idle or when moving? Trying raising the passenger side front and start the car cold with the cap off and let it run for a while. It will make sure there is no air pockets in the system.
Old Aug 22, 2005 | 11:21 PM
onaqwst's Avatar
onaqwst
clogged intake
Old Aug 26, 2005 | 11:15 AM
not a '76's Avatar
not a '76
yea... define overheating
To having overheating problemswith my 78'need help?
