Antenna Cable
Old Aug 28, 2005 | 04:40 PM
Localbulldog's Avatar
Localbulldog
Default Antenna Cable
Dumb question but ....... How do I disconnect the antenna cable from the antenna base on a 76 ? Does it pull out or turn out ? Thanks.
Old Aug 28, 2005 | 06:01 PM
Maymyvetteliveforevr's Avatar
If your referring to the non power antenna on a 75 it's one piece and the connection can be found a couple of feet into the trunk area. In other words, it doesn't separate at the antenna.
Old Aug 28, 2005 | 06:57 PM
Localbulldog
Cool thanks.
Old Aug 28, 2005 | 09:39 PM
Localbulldog
Maymyvetteliveforever,
I looked for the cable connection you spoke of...........2ft from the antenna end?
Old Aug 29, 2005 | 06:08 PM
I just checked mine and it goes all the way to the radio. It's approximately 9 feet long. I was wrong when I said there was a connection a couple of feet away.
To Antenna Cable
