How much force to push your C3?
Old Aug 28, 2005 | 05:06 PM
1972warship's Avatar
1972warship
Default How much force to push your C3?
I have always noticed it takes a lot more force to push my 72 vette a couple of ft than my other much newer cars. I have always contributed this to being an old car with old technology(read heavy drivetrain components, etc.). Is this a true assumption or should I look at anything. This seems to me that it would take a lot more hp to get this car moving, and I want to reduce this(especially if there is a problem).
Old Aug 28, 2005 | 05:57 PM
Techno's Avatar
Techno
I pushed mine up a slight incline to my gargage. Doesn't seem to be harder than my 91 dynasty but never pushed that.
Tires might have something to do with it. Are the Vette tires much different than the newer cars tires in width and tire pressure?
Old Aug 28, 2005 | 05:58 PM
lostpatrolman's Avatar
lostpatrolman
I dont have any problems pushing mine. What kind of cars are you comparing this to? A light honda civic, or a heavy firebird?
Old Aug 28, 2005 | 06:06 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
It used to be easy to push mine when I had the 5-speed in it (in neutral of course)..
Since I installed the 12-bolt rear end and automatic, it's much harder to push the car... I have no idea if this is normal..
Old Aug 28, 2005 | 06:59 PM
VETDRMS's Avatar
VETDRMS
Oliver: You have to take it out of park. :
Old Aug 28, 2005 | 07:10 PM
chris75stingray's Avatar
chris75stingray
if i try to push mine from the door its real hard, but if i push from the back and lift on the rear bumper it seems to go real easy.
Old Aug 28, 2005 | 08:03 PM
lowbuck72's Avatar
lowbuck72
If you're running 235 or 255 section width tires and they're a little low on air, your C3 will be harder to push. If you're air pressure is ok and your vette is still hard to push, try this: On lever ground push it a couple of feet forward, then push it a couple of feet backward. If it's a lot easier to push one way as compared to the other, your toe could be off. If so, it's gonna hurt your fuel mileage as well as prematurely wearing out you tires, but it's an easy fix.
Old Aug 28, 2005 | 09:37 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
are you sure your parking brake is disengaging and retracting?
Old Aug 28, 2005 | 09:54 PM
1972warship
lostpatrolman: I am comparing it to a 2000 acura TL(about 3500lbs).
Grandsport: Mine is a 700R4 automatic...(im trying in neutral, and you are the man if you can push yours in park....just kidding
techno: I am running bfg 255/60/15's
lowbuck72: running 255's and I just check the air. Interesting about the suspension..I just had mine re-aligned(hope the guy knew what he was doing). I did just jack up the back and the back tires seem to drag when I spin them....I haven't tried, but it would seem that it would not be easy to get them to spin a complete revolution(without a lot of force,,,this is probably normal with the disc brakes).
bobs77vet: The parking brake does not exist on my car
I appreciate all of your input. I just want to make sure there isn't something wrong with my car.
Old Aug 28, 2005 | 09:56 PM
big_G's Avatar
big_G
Every year I push my vette, it seems harder and harder..what's up with that?
Old Aug 28, 2005 | 10:05 PM
Bangkok Dean's Avatar
Bangkok Dean
I don’t see any difference in when my wife pushed me in the Vette or pickup truck
Old Aug 28, 2005 | 11:32 PM
carl a's Avatar
carl a
thats because you guys are trying to push it sideways,try pusing from the rear going foward!!!!
Old Aug 28, 2005 | 11:33 PM
carl a's Avatar
carl a
thats because you guys are trying to push it sideways!! try pushing foward!!!!!!!!!!!!!!!!!!!!!
Old Aug 29, 2005 | 12:10 AM
LS-Five's Avatar
LS-Five
East bound and down...
I would check the wheel bearings as well. After I redid all four of mine, the car rolled much easier than before.
Old Aug 29, 2005 | 01:52 AM
PhotoVette1's Avatar
PhotoVette1
Mine pushes with little effort; I roll it in and out of the garage for washing...
You might want to fix the problem ASAP; it'll be a real bitch to push it in the soon-to-come gas lines if you don't.
Old Aug 29, 2005 | 09:14 AM
GrandSportC3
Old Aug 29, 2005 | 09:48 AM
GrandSportC3
hmm.. I wonder if my 28 x 13.5 - 15 ET Street slicks cause all the resistance...
To How much force to push your C3?
Old Aug 29, 2005 | 10:14 AM
rihwoods's Avatar
rihwoods
Mine will start rolling very slowly by itself from the garage after releasing brake.....with me in it...
Old Aug 29, 2005 | 11:49 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
I've gotten pretty good at pushing mine over the years
Old Aug 29, 2005 | 10:02 PM
oregonsharkman's Avatar
oregonsharkman
Yeah I know what you mean
