Header Coating Discolor
Old Aug 31, 2005 | 10:42 AM
captainmorgan's Avatar
captainmorgan
Default Header Coating Discolor (BG carb adjustment?)
The coating on my header's are starting to discolor. They and the Dynomax ceramic coated headers.
Does this mean that the car is running too lean or too rich?
Anyone else having this problem with their Dynomax header's?
Old Aug 31, 2005 | 10:45 AM
Fevre's Avatar
Fevre
Lean will give higher exh temps which might give discoloration, mine are not a bright and shiney as when they where new but still look pretty good except for the scratchs.
Old Aug 31, 2005 | 10:57 AM
Boofers's Avatar
Boofers
There were some posts a few weeks back saying that high exhaust temps can be caused by too lean or too rich, that the best way to tell is to look at your plugs or have the a/f read like at a dyno.
http://forums.corvetteforum.com/show....php?t=1161905
Old Aug 31, 2005 | 11:15 AM
captainmorgan
I have a Barry Grant 575 Speed Demon with mechanical secondaries.
If it is running lean what is the best way to adjust it so it will run richer?
It has been rejetted with 72 and 65 jet sizes.
Old Aug 31, 2005 | 05:57 PM
captainmorgan
Why is this not tech/perf?
To Header Coating Discolor
