82 Front air deflector.
Old Sep 2, 2005 | 02:41 PM
rafto's Avatar
rafto
Default 82 Front air deflector.
The air deflector was missing when I got it and am putting one on. Does it go above the hook in the center or below. Tried it both ways but it seems flimsy. Probably would rattle a lot at highway speed. Is there any other bracing that I'm missing?
Old Sep 2, 2005 | 02:49 PM
Jim Martley2's Avatar
Jim Martley2
It sits on top of the "hook". There are no other mounting brackets as it is supposed to "float" when you hit something solid with it.
Old Sep 2, 2005 | 02:56 PM
rafto's Avatar
rafto
Is there another piece in center? Where the two air dam extensions meet?
Old Sep 2, 2005 | 03:50 PM
Twin_Turbo's Avatar
Twin_Turbo
yes, it's 3 pieces, 2 rubber skirts and a fiberglass V shaped piece.
Old Sep 2, 2005 | 04:33 PM
texaswilkins's Avatar
texaswilkins
The replacement fiberglass piece doesn't take road impacts very well. Make sure you have it installed level or you'll get an expensive trip to the body shop.
Bill
Old Sep 2, 2005 | 05:33 PM
rafto's Avatar
rafto
Default 82 air deflector
In your picture it looks like there is something mounted in the center that goes to the front asm. Don't have that on mine... Looked in assembly manual and it doesn't show anything either.
To 82 Front air deflector.
