Dammit!
Old Sep 4, 2005 | 01:30 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Dammit!
I just finished 5 days of replacing the heater core, new seals, new expansion tank etc. etc. at http://forums.corvetteforum.com/show....php?t=1174120 and everything worked fine pumping good amount of hot air out the vents but this morning I showed my wife all my hard efforts and I just turned the key to ACC and turned the fan switch on and it sounds like the fan motor bearings are going bad. I never turned the fan on with the car off so the exhaust noise masked the blower motor's noise. Also the clock starts moving for 10 seconds then stops but puts a load on the battery. Well I'm not sure if I'm going to do anything about the clock save pulling the fuse. The blower motor requires pulling the expansion tank, hoses, outer heater box as the fan blade (a squirrel cage) is bolted to the blower motor drive shaft and the blades are larger then the hole the motor fits in. Well at least I don't have to remove the interior to replace the blower motor. I think I'll do nothing for now. I'll use the blower motor till it burns out, maybe get a few months out of it. Then order a new motor and quartz clock. I just don't want to go thru all that cra$ all over again. At least for now.
Old Sep 4, 2005 | 01:34 PM
TonySinclair's Avatar
TonySinclair
Welcome to the Club! I feel your pain.
Can't tell you how many times I've had to do something twice/thrice just to get it right.
I've learned to replace "difficult-to-reach" stuff with new while I have an assembly apart.
Famous last words: "It looks OK...I'd re-use it"...
Old Sep 5, 2005 | 01:39 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Hey David :
Nice car show pics, you should sell me your vert, I could have saved you a ton of work.
I don't need a heater out here anyway!!!
Old Sep 5, 2005 | 01:30 PM
Cali,68,L-79
You know when the heater/ blower assemblies were apart I thought hey lets hook up two wires directly to the Nissan's battery (car sitting next to the Vette) but I was scared that without the resistor I'd blow the motor and i have no idea what the resister does.
Desertdawg you can have my 68. I'll pay for your flight out. Just bring 25K and another $400 to cover gas getting back home.
Old Sep 5, 2005 | 02:55 PM
Techno's Avatar
Techno
You can try spraying some oil into the blower. The cooling hose that leads from the fan to motor. Spritz some P oil in there. Sometimes it works.
Old Sep 5, 2005 | 11:07 PM
Cali,68,L-79
I'll give it a try. thanks.
Old Sep 6, 2005 | 02:02 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
25. ouch, I thought you were going to cut me a deal on it, something like 10????
Besides just think of all the cool thumbs up I would get from everyone, even if I do have to sleep in the dog house..
Old Sep 6, 2005 | 07:47 PM
Techno's Avatar
Techno
I didn't notice at first but why will he need $25,400 for gas money? I know gas is high but damn!
Desertdawg where do you live? Peru? Or Argentina?
Old Sep 7, 2005 | 12:31 AM
Cali,68,L-79
25K for the car and $400 for gas to AZ.
To Dammit!
