1974 Outer door handle removal???
Old Sep 5, 2005 | 08:21 AM
frisk3's Avatar
frisk3
Default 1974 Outer door handle removal???
Got 2 days off and decided to swap out my original outer door handles. I did a search and got nothing and went back 25 pages on C3 general and found nothing as well. I have a shop manual and removed the door panel and the freeze/water shield. Fortunately the rear nut holding the handle was not on all the way and I was able to remove it by hand. What tool has anyone modified to tighten this rear nut up. There is little to no room to get anything in there. I have not removed the locks yet. Is this the key to remove the arm that attaches to the handle? I can't seem to unhook it otherwise.
Thank you to all that reply and have a happy and safe Labor day.
GEORGE
Old Sep 5, 2005 | 09:15 AM
Star79's Avatar
Star79
On my 79 I could loosen/tighten the nuts with a small ratchet with a long extension, not sure if clearance is similar on a 74.
For the "rod", it was easier to undo it at the bottom (loosen screw that holds it into the latch parts) rather than remove it from the handle. Then you can get the rod off withthe whole handle off the car. Putting it back on takes a few tries to line it up while dropping it back in.
Old Sep 5, 2005 | 09:20 AM
frisk3's Avatar
frisk3
In my case there is no room for a socket. I was thinking of modifying an open end wrench or?
I saw the attachment at the bottom of the rod. This may be the way to go.
GEORGE
Old Sep 5, 2005 | 09:45 AM
FeedVaal's Avatar
FeedVaal
I now consider a ratcheting box end wrench essential for this job, makes things much easier.
Old Sep 5, 2005 | 11:18 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
1/4 inch drive socket set. 12 inch "flex" extension. "Screwdriver handle" driver, not a ratchet.
Loosen/remove the screws in the door jamb and let the latch fall down to give you more room. Chuck
Old Sep 5, 2005 | 11:22 AM
frisk3's Avatar
frisk3
Thanks Chuck. I thought about loosening the assembly and dropping it down but wasn't sure if i was opening up a bigger can of worms.
Many thanks
GEORGE
Old Sep 5, 2005 | 11:57 AM
71redskin's Avatar
71redskin
most guys including me left the nut off thats closest to the jam... you'll never know the difference......mine works fine
Old Sep 5, 2005 | 12:13 PM
frisk3's Avatar
frisk3
With the door mechanism lowered there is a ton of room. You could now use a wrench and tighten the bolt. A major difference!! Now if I can just re-install the lower clip hooking the arm to the mechanism I'll be done
GEORGE
Old Sep 5, 2005 | 03:33 PM
Star79's Avatar
Star79
Correction on my first answer, I had my door apart again today and yup the one nut you can't reach was just left off.
I also tried to put on an aftermarket outside handle. What a piece of crap! Looked great in it's box, but didn't fit (had to grind a chunk off) and after an hour or so adjusting it, it wouldn't open the door, and it already started sagging down/not returning up. I took it out and put the original broken one back in, I'd rather keep opening the door from the inside than look at that P.O.S.
To 1974 Outer door handle removal???
