Stupid Ignition Setup Questions
Thanks guys.
Edelbrock
The newer Vette engines like the LS1, LS2, LS6 are distributorless (DIS). GM sells them as crate motors, but they're small blocks - nothing as big as the 502. DIS systems are more complex and require special pieces for fitting on an engine like the 502. Many aftermarket ignition systems will work with DIS, but you'll need some extra parts to send the system a signal to tell it about the cam position since the stock type distributor doesn't know about it. MSD makes a lot of these parts. You'll also need a coil for each cylinder.
MSD
Here's a 502 equipped with the Edelbrock efi already installed.
Sallee
You'll also need to upgrade the fuel system to a high pressure system for efi. Usually this means a new electric fuel pump, regulator and new lines including a return system. There are a ton of fuel pumps and regulators out there.
'75s come with an electric tach, so you're in good shape there.
Last but not least, you'll need a place in the exhaust system to install the 02 sensor.
Good luck -
Calculations
If your EFI don't have it but supports it seems a cheap and simple system to add.
