Steeroids installed, and I'm dialed!
When I get off work today I'm headin' for the mountains for a sweet cruse!
Over the past few months I've did Van Steels Trailing Arm Rebuild, did a frame restoration with Van Steel Kits: All front and rear rubber and bushings and bearings, The Street and Saloom Suspension kit, Bilstiens, sway bars, fiberglass spring, u-joints, all new rotors and brake pads, hoses, speed bleeders.
The front pump on the th400 transmittion was leaking so I pulled it out and replaced seals all around while the opportunity was there. What the heck, while I was at it, I pulled the Rear End, installed new seals and changed oil with RedLine.
I also had the radiator rebuilt, and had all the A/C flushed, hose rebuilds, everything was replaced except the evaporator and condensor.
The air is cold. The cabin by good fortune has no heat seal-out issues.
I rebuilt the stock steering, it was good but I wanted better; so I ripped it all out and installed the Steeroids.
So now with the Conastoga Wagon Steering issues out of the way........
I'M DIALED!!!!!!!!
P.S
I couldn't have got this far without you guys!
I knew nearly nothing when I began this trek.
My heart felt thanks goes out to all of you. THIS FORUM ROCKS!
What do you think about this kit ?
http://www.corvettesteering.com/55-57%20chevy.htm
Cheaper than Stereoid and not hanging so low on the ground.
Günther
Günther
Günther
My problem is the stock relay rod that it connects to is a cause of slop also. So even with a good quality P/S box you still end up with some slop in the steering.
I am trying the steeroids to see how that works.
Günther
vett fiddler sounds great now you can enjoy the car.
I'M DIALED!!!!!!!!
P.S
I am about to order my kit (next week) and I have been reading through the forums and information on the speeddirect site. Did you replace the bearing they mention in bullet 2
http://www.speeddirect.com/index.aspx?nodeID=115
I am trying to figure out what bearing this is and if a) it is something I should order ahead of time or b) it is something i can get at the local auto parts store and c) what the heck bearing it is anyway.
Other than that, any other tips? I think I am going to order exhaust headers at the same time.
Shane
Shane
Last night I serpentined
over the mountains then cruised back home over Interstate 580/680 and it was like a different car.
I'm amazed. The response is there. I kept my new/old parts just in case, but I know now I will never go back!Tips? Install and Torque the hose adapters (located on the R/P unit) on the bench .....rather than under the car. They don't tell you that.
Also, the intermediate u-joint shaft that they included was 1/2" to short.
I jockey things around to get a set screw bite on the lower half of all the spines in the combination.
I did not like that!
Also, you may want to order boots for the Hiem-ball joint. They say they are not needed (if you want to believe that) So.Cal ran a thread that Twin Turbo responded too with good advice and a web site to buy them
within the past week. Also, Using a set of tall ramps to hold the wheels strait (from another thread) may be helpful. Or you could ignore the tires squeeling on the way to the alignment shop.
Shane- Have fun and relaxation putting in the kit. Then enjoy!
Shane
heres my install go to post 3 for the bearing in question and the next couple of posts show the install
http://forums.corvetteforum.com/showthread.php?t=960162
What is that bearing called and where can I get one? I figure if I am going to rip everything out I might as well replace little items like these.
Shane
Shane
